Sponsored by: Real Truck
sway bar links?
Old Oct 21, 2004 | 07:41 AM
ttb29's Avatar
ttb29
sway bar links?
my 2000 f-250 4x4 has a bad raddle in the front end and found it was the sway bar links. ford dealer wants 48.00 per side for new ones. is this normal on the super dutys? is there a cheaper way to go?
Old Oct 21, 2004 | 08:25 AM
02superstroker's Avatar
02superstroker
you probably jsut need the new bushings? I would think you could get those cheaper than that...
good luck
Old Oct 22, 2004 | 02:44 PM
Bigmark'sblownv10's Avatar
Bigmark'sblownv10
If you go with an aftermarket sway bar link, MOOG seems to be the best and strongest & probably less $. But if you have over a 4" lift, go to TUFF Country, they have extended sway bar links.
