Throttle Position Solenoid
Old Jul 12, 2016 | 09:18 AM
Finmad's Avatar
Finmad
Can someone give me a rundown about the Throttle Position Solenoid? How it works and why?
Also is there a way to check and see if it is functioning correctly.
Old Jul 12, 2016 | 09:26 AM
Filthy Beast's Avatar
Filthy Beast
You could do a search on the 'net or this forum.
Go here:
https://www.ford-trucks.com/forums/1...rb-tuning.html
Old Jul 12, 2016 | 10:12 AM
Finmad's Avatar
Finmad
Thanks for the links, I read the Choke operation in the Sticky thread already and also the other link was good as well. My carb is running well, just a slight hesitation at 1/4 throttle from a stop. and when my AC is on the idle is too low. so I was wondering if that was the function of the Throttle Position Solenoid.
Old Jul 12, 2016 | 10:29 AM
mikeo0o0o0's Avatar
mikeo0o0o0
That's actually an anti-diesel solenoid.
Back in the day, because of the somewhat prehistoric emission control systems, when you shut the ignition off the engine sometimes wanted to run-on (aka "dieseling"). The way Ford tried to avoid this was this solenoid.
With the ignition on, the solenoid is extended and holds the engine at the set idle speed. When you turn the ignition off, the solenoid de-energizes and retracts. This allows the throttle to close completely. Hopefully it would keep the engine from dieseling. Sometimes it worked, sometimes it didn't.
With modern fuel injection, there is no dieseling problem. You shut the engine off, you shut the fuel supply off. No way to diesel.
Old Jul 12, 2016 | 10:33 AM
Filthy Beast
Originally Posted by Finmad
....when my AC is on the idle is too low. so I was wondering if that was the function of the Throttle Position Solenoid.
Yes, it is... and activated by the ignition switch. It's also supposed to be an "anti-dieseling" unit as well.
From another forum - To adjust: first unplug it and back off the screw so it won't contact the throttle linkage. Then adjust the idle speed to 500 rpm with the throttle plate stop screw (just on the edge of a stall). After that, plug in the solenoid and adjust the curb idle to 800 rpm (or what's listed on the emissions sticker if it's still there). All of this is done on a warm engine.
This allows the solenoid to control the curb idle, and when the key is turned off the solenoid retracts and allows the throttle plate to close enough to prevent shut-down dieseling with a hot engine.
Old Jul 12, 2016 | 10:45 AM
Finmad's Avatar
Finmad
excellent, that was perfect.
Old Jul 12, 2016 | 10:54 AM
Filthy Beast
Happy to help.
chapinjerau
Nov 13, 2016 07:39 AM
Jnissen04
13
Apr 25, 2014 12:16 AM
LARIAT 85
Sep 21, 2013 12:54 AM
MikeKrock
Mar 1, 2011 08:36 PM
rdweathers
Jun 17, 2010 11:25 PM
