Sponsored by: Real Truck
4wd problems
Old Jul 11, 2016 | 06:35 PM
Skrogers's Avatar
Skrogers
4wd problems
F350 with Warn Manuel hubs will not go into 4wd. When dash switch is change to 4wd hvac goes to defrost. Do I have 2 problems i.e.: vacuum leak and transfer case problem? Does vacuum system have anything to do with transfer case or just auto hubs that I replaced with warn hubs? Everything was working fine for a couple of years but just tried 4wd and problems. Thanks for my help.
Old Jul 11, 2016 | 07:28 PM
Hoss416's Avatar
Hoss416
Did you plug the vacuum lines for the auto hubs?
Old Jul 11, 2016 | 08:16 PM
Skrogers's Avatar
Skrogers
Yes, when hubs installed. Worked great for 2 years.
Old Jul 12, 2016 | 05:29 AM
redford's Avatar
redford
FTE Leadership Emeritus
You have a vacuum leak. Your system defaulting to the defrost is a sign of that, but if you have Warn hubs you don't need vacuum to lock the hubs, so I am a bit puzzled by your statement that your 4 wheel drive system isn't working.
Do your Warn hubs lock when you turn them? Why are you saying that you don't have 4 wheel drive?
Old Jul 12, 2016 | 06:50 AM
Skrogers's Avatar
Skrogers
I will check to make sure hubs are locking. Thanks.
Old Jul 12, 2016 | 07:49 AM
MisterCMK's Avatar
MisterCMK
Plug the vac feed to the solenoid on the fender. That solenoid may be cracked as well.
High_HP
Jun 15, 2017 01:25 PM
kconrad
Oct 24, 2012 03:19 PM
Hoop
Mar 19, 2007 08:36 AM
rascal1
Mar 4, 2007 03:49 PM
IDIFREAK
Dec 2, 2006 12:01 PM
