Sponsored by: Real Truck
5.4 Exhaust Studs
Old Jul 11, 2016 | 04:19 PM
Coachhick's Avatar
Coachhick
5.4 Exhaust Studs
I've been studying on this topic and I'm about to proceed on fixing my passenger side exhaust squeal that has been present since I purchased the truck. All studs are there, but last week I finally put a wrench on them and the front 2 just spin and spin....you can also feel the leak with your hand when you crank the truck.
Question #1 - Do the studs seize in the heads (the unbroken ones)or do they come out pretty easily?
Question #2 - Is it ok to go back with stainless studs?
Question #3 - I assume I should replace all the studs while I have that side off, is it common for studs to break when you are trying to remove them?
Old Jul 11, 2016 | 05:52 PM
Bigpipes 35's Avatar
Bigpipes 35
In my case the studs didn't seize in the head but they did break off as you tried to remove them. In my case I had three break off even with the head and for that the common approach is to weld a nut on the end of the stud with a wirefeed welder in which I did. This worked for two out of the three. The third one I had to drill out and tap. I used stainless studs as my replacements. I also did both sides which takes twice as long. It is a pain in the butt to do this and your back will not be happy with you when you are done..
Old Jul 11, 2016 | 08:43 PM
GN1220's Avatar
GN1220
Do you have a parts list of the bolts needed to correct this issue? Seems like a good preemptive move to go ahead and replace them all with stainless.
Old Jul 11, 2016 | 08:46 PM
Bigpipes 35
I don't remember the part numbers I got mine on Ebay, just punch in 5.4 exhaust studs..
Old Jul 13, 2016 | 12:05 PM
droldsmorland's Avatar
droldsmorland
Have a look at the threads below. The new studs n nuts are improved material. The stealership had them and they were not too much. Was not as bad as I thought it was gona be...not sayin it was fun by any means.
https://www.ford-trucks.com/forums/1...-opinions.html
https://www.ford-trucks.com/forums/1...+exhaust+studs
Old Aug 21, 2016 | 08:38 PM
GN1220's Avatar
GN1220
Any idea what they cost from the dealership? Can get the studs in a few days off ebay for $16. I need them asap and would rather go to the dealer but if it's considerably more I will order them tonight.
Old Aug 22, 2016 | 08:58 AM
droldsmorland
I dont remember I did this 5 years ago. Parts to do one side that included gaskets, studs nuts and the head pipe 3 studs n nuts was around 100 or so if memory serves me? Give the stearleship a call and ask. Have the last 7 or 8 numbers of the trucks VIN available as they will ask for it.
Old Aug 22, 2016 | 09:30 AM
wizkid00104's Avatar
wizkid00104
I have been looking at these studs: Ford 4 6 5 4 Liter V8 Stainless Exhaust Manifold Stud Kit for 2 Manifolds | eBay
And these gaskets: https://www.summitracing.com/parts/sce-4046
The stainless and copper should elminate future issues. I was going to get my manifolds ceramic coated to for extra protection and use antisieze on all the fasteners.
Old Aug 22, 2016 | 09:48 AM
44dwarf's Avatar
44dwarf
Those metric SS studs are the ones I'll be going to on my v10. The company that sells them is close to where i grow up and they don't sell cheap junk they supply metric stuff to many of the area MFG companies and shops so that's why I'll go with them.
z31freakify
Oct 13, 2016 04:36 PM
08bustedknuckle
Aug 20, 2015 04:14 PM
hopperwagonbob
Modular V8 (4.6L, 5.4L)
Jan 25, 2009 09:39 AM
DaveandJennyP
Modular V10 (6.8l)
Sep 13, 2008 07:09 PM
1pfieffer1
Dec 5, 2007 11:16 AM
