Alternator Bracket?
Old Jun 21, 2010 | 06:07 PM
JoeTaco1's Avatar
JoeTaco1
Exclamation Alternator Bracket?
My dad just brought home my replacement alternator today, but the problem is that the holes on my old alternator are at 12 and 6 o'clock, and the new one is at 12 and 3 o'clock. is there anyway to take the bracket off the old alternator and replace the one on the new alternator? help is appreciated. asap. thanks!
Old Jun 21, 2010 | 06:28 PM
bashby's Avatar
bashby
You can re-clock the alt, but you should be able to return it and get the right one. It's easy to mess up the brushes when re clocking then they might not take it back
Old Jun 21, 2010 | 09:06 PM
Archion's Avatar
Archion
Veteran: Marine Corps
You cant reclock the bolt holes, only the wiring positions, you need the correct alternator. There are two different ones. If the painted bolts are broken, most places will not accept the return
