tire rub
Old Jan 16, 2002 | 07:21 PM
orange peel's Avatar
orange peel
tire rub
'87 f-150 with a 6" lift with longer radius arms, runnin 36" tsl's that are mounted on 15x8's (for now because i havent ordered the 15x10's yet), the tires are rubbin on the radius arms, i was hopein that the reason for the rub was because of the small wheels. thanks for any help.
Old Jan 16, 2002 | 08:37 PM
orange peel
tire rub
i would like to hear from hippiecustoms since he is runnin 39.5's on his rig. also if puttin the 15x10's on it wont help what will.
Old Jan 17, 2002 | 08:56 PM
HippieCustoms's Avatar
HippieCustoms
tire rub
The way I fixed mine was, if you look at the steering knuckle or spindle, right where the spindle hits the axle at stop, there is a whole. There was in mine. I tapped that hole and threaded a bolt into it so the bolt head would hit instead of the spindle. When I had the 35's on it, all I needed was the thickness of the bolt head to keep the tires off the radius arms. But I had to put washers under the bolt head when I went to the 39's. Turn radius is smaller, but not much and very managable. Hope this helps. Good luck.
Old Jan 17, 2002 | 11:31 PM
orange peel
tire rub
thanks man, ill try that all though i wanted to try to stay away from any ghetto work like that but hell if it fixes it who cares.
Old Jan 18, 2002 | 01:44 AM
madman666's Avatar
madman666
tire rub
Backflip164
Dec 2, 2014 02:45 PM
Mush's 88
Dec 29, 2004 09:20 PM
Oso13
Aug 21, 2003 12:19 AM
slifer
Mar 5, 2003 01:24 PM
4xfordman
Jan 29, 2002 10:30 PM
