aod question
Old Jul 10, 2016 | 07:30 PM
brandonbeezy's Avatar
brandonbeezy
aod question
82 f150 302/aod, I swapped from a 2bbl to a 4160 holley need to know which tv cable kit yall like and how you set it up, hows it preform. was it easy to adjust?
Old Jul 11, 2016 | 10:09 AM
LARIAT 85's Avatar
LARIAT 85
I used the Lokar TV cable kit on mine. I have had it for 10 years and it still works great. I like it. I think it is easier to adjust than the stock TV rod was.
It is EXTREMELY important to have the TV cable adjusted correctly! If you don't, you can destroy the AOD very quickly.
This thread should answer all of your questions:
https://www.ford-trucks.com/forums/1...th-an-aod.html
Old Jul 11, 2016 | 10:38 AM
brandonbeezy
Thanks buddy i had the lokar in mind, hows your truck run with all that done to it. I read your sig and had to ask lol i had a b &m 144 supercharger i was gonna put on mine but traded it for a gs1000 lol
Old Jul 11, 2016 | 03:34 PM
Cienega32's Avatar
Cienega32
A quick question: what obvious differences (if any) are there between the TV and KickDown rods themselves?
Old Jul 11, 2016 | 04:24 PM
brandonbeezy
Has to do with the adjustability part. The holleys and other aftermarket carbs wont work with the kick rod because the linkages dont have the proper ratio needed
Old Jul 11, 2016 | 04:25 PM
brandonbeezy
There are videos on youtube explainng it better than I can
Old Jul 11, 2016 | 05:12 PM
LARIAT 85's Avatar
LARIAT 85
An AOD TV rod looks exactly like a C4/C6 kickdown rod on the carburetor end. On AOD-specific carburetors, the TV linkage will have a small adjusting screw where the TV rod connects for fine tuning of pressure/shift points. (Aftermarket carburetors don't have this.)
On the transmission end, the TV rod is threaded with an adjustable block for the coarse pressure adjustment.
Old Jul 13, 2016 | 12:11 AM
Cienega32's Avatar
Cienega32
Mine is smooth with a flat side for a set screw in the adj block at the tranny.
Reason why I ask about any differences is during rough adjustments (as per Ford manual), I always seem to have the block at the upper end of the travel area. I can get the pressures right at the carb adj but it always struck me as odd that I would run out of rod at the tranny end with the course adj.
Truck originally had the wrong carb on it and shifted from 1st to 3rd or maybe OD when I got it! I was able to bring it to spec with the wrong carb and had nice smooth shifts and on time but wanted the right carb for obvious reasons.
Since putting the AOD carb on a few years back, the course adj never felt right as far as position on the rod. Hence, my concerns!
reed1951
Jan 2, 2014 05:50 PM
Rick_Fury
Jan 28, 2010 11:27 AM
pipman76
Engine Swaps
May 28, 2009 10:27 PM
gov2mod
1978 - 1996 Big Bronco
Sep 26, 2005 12:11 AM
learpilot
Sep 27, 2004 01:12 PM
