Idi vs powerstroke
Old Jul 9, 2016 | 07:19 PM
Jesse73iditurbo's Avatar
Jesse73iditurbo
Idi vs powerstroke
I got my 7.3 I did factory turbo. Single cab long bed 4x4 with a 5 speed. Pretty much stock except exhaust and fuel turned up a notch but idk how much cuz I didn't do it and I have a small skip and I think it's the injectors but I'm not sure. My friend has a 96 psd and his a single cab long bed 4x4 automatic. It has a 5 pos chip with 6 inch lift Springs with 37s. He thinks it could have a bigger turbo but he doesn't really know. He also thinks his truck needs injectors cuz it has a small skip to it. The other day we drag raced for the heck of it down a 2 lane highway and I smoked his truck and his was allike the way on performance setting on the chip. I know they probly both need injectors but what's your opinion of this? I'm not in it to have a race truck it was just for fun but I would of assumed if it's true that nothing trucks need injectors and mine pretty much stock that the psd would of beat me.
Old Jul 10, 2016 | 07:30 AM
bashby's Avatar
bashby
If he had smaller tires results may be different.
Old Jul 10, 2016 | 07:47 AM
Diesel_Brad's Avatar
Diesel_Brad
Tires, gearing, vehicle condition, driving style all play a part
Old Jul 10, 2016 | 08:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
agreed. his large tires hurt him.
but on the other side of the coin a properly running turbo IDI is about equal to a stock powerstroke.
so with his oversized tires, and your turbo on the IDI, you were pretty much equal on engines.
Old Jul 10, 2016 | 10:59 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
torque wins races.the idi has loads of base compression,giving you the advantage off the line.combine that with his big heavy tires and he didn't stand a chance.
Old Jul 10, 2016 | 11:42 AM
Jesse73iditurbo
What about the idea of us both having bad injectors? And his is chipped
Old Jul 10, 2016 | 12:32 PM
tjc transport
i ain't rite
chip don't mean much from an idle.
plus, you had the advantage off the bat with the 5 speed. his automatic did not lock the torque converter until he was doing around 25-30mph.
Old Jul 10, 2016 | 01:11 PM
Jesse73iditurbo
True I didn't think about that my he said he wants to get stage 2 injectors. I'm gunna replace mine with stock replacements and do my cold air intake that I havn't had time for yet. I'm sure then if we raced he probly beat me.
Old Jul 10, 2016 | 02:03 PM
FORDF250HDXLT
the zf5 is no match for the e4 in a drag race.the psd had a huge advantage in this regard.however no where near enough to compensate for those huge meats and tall effective gearing.all else being equal,the e4od hands the zf5 it's ars at the strip.
Old Jul 10, 2016 | 03:44 PM
tjc transport
i ain't rite
it is all up to the driver. if you know what you are doing and the person with the "bigger engine" does not, the "bigger engine" driver is going to loose the race every time.
Old Jul 10, 2016 | 04:16 PM
Lead Head's Avatar
Lead Head
Hard to not know what you're doing with an e4od. Just floor it.
A late factory turbo idi and early psd will be close to each other. The 7.3 truck has the huge tires working against it, and if it had a skip, it probably has tired injectors and or a weak hpop system. A tuned 7.3 should smoke a near stock idi.
Old Jul 10, 2016 | 08:06 PM
Diesel_Brad
Don't forget GEARING
psd96
Jan 5, 2026 05:54 AM
Redneckmorton
Jun 28, 2013 08:30 AM
c00nhunterjoe
57
Apr 6, 2010 09:29 PM
texandually
Oct 2, 2009 10:39 PM
Brown Falcon
Jun 29, 2009 02:17 PM
