Found the problem!
Old Jul 9, 2016 | 12:46 PM
Coastal68's Avatar
Coastal68
Found the problem!
I was getting a little friction from the flexplate when I reinstalled the starter and rotated the motor by hand. The remanufactured starter is hitting the flexplate. Apparently this is a somewhat common problem as I found several pics online of similar damage to starters on FE motors. Here's mine::
So, TC was installed and bolted to the flexplate correctly and the spacer plate was fine. I'm guessing there is enough play in the alignment that it can rotate slightly and hit the FP.
Old Jul 9, 2016 | 01:02 PM
HIO Silver's Avatar
HIO Silver
"A-ha!" moments are to be celebrated...
Use grinder. Make fit.
Old Jul 9, 2016 | 01:09 PM
Coastal68's Avatar
Coastal68
Oh yeah, this thing's gettin hit with the grinder.
I'm just relieved it was this simple.
EDIT: hit it with the grinder, installed it and now it clears the flexplate. Don't know why, but apparently it's possible to buy a starter for these motors that will bolt up but still interferes with the flexplate or flywheel.
Old Jul 9, 2016 | 02:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are TWO different FE starters, 1958/62 that uses the HUGE Bendix inertia starter drive, and 1963/76.
Old Jul 9, 2016 | 07:08 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
I had an alignment pin missing from an engine it put the starter in the wrong spot and caused something like that
Also the holes on the starter are a bit oversized if it was spun clockwise enough that could do that maybe you could try rotating it a bit counter clockwise my guess is that's probably not what caused that because it shouldn't have that much play
Old Jul 9, 2016 | 09:21 PM
Coastal68's Avatar
Coastal68
I checked for play while I was bolting it back in and there was plenty. Just looking for other examples of this problem with an image search tuned up a fair bit of variation from one brand to another, so it's easy to see how tolerances could be a bit loose.
As far as I can tell, this is the only explanation for why this wasn't a problem before with the same starter.
Old Jul 10, 2016 | 01:48 AM
GaryKip's Avatar
GaryKip
Glad you found it now.
Old Jul 10, 2016 | 06:09 AM
Coastal68's Avatar
Coastal68
Found a pic of the old style. It's huge, alright.
granny_rocket
30
Jun 28, 2012 07:47 PM
marty68
15
Nov 20, 2009 03:03 PM
bubbatom
Aug 29, 2008 04:54 PM
AFSOCmech
Feb 17, 2006 09:28 PM
taxidriver
Nov 10, 2004 11:54 AM
