Need help diag. a short
Old Aug 15, 2012 | 11:00 PM
coollooking96F350's Avatar
coollooking96F350
Hey Guys/gals,
I have a 1996 F-350. It is popping #13 fuse under the dash. Brakelights/hazards, ABS. I can't figure out why. I have un-hook a couple of harnesses, but still getting the short. Disconnected the trailer brake controller and ABS switch in the rear end too. Can it be one of the rear or front turn signals?
Anybody have this problem? Frustrated at this point. Any help greatly appreciated
Old Aug 15, 2012 | 11:38 PM
madpogue's Avatar
madpogue
Remove all the bulbs involved, including the center stop light in the cab roof. If that keeps the fuse from blowing, start reinstalling them until it blows. If it still blows with all the bulbs removed, then you're lookin' at a switch (BOO or hazard switch), or a wire chafed and shorting to ground somwhere. Those can be loads of fun to find.
Old Aug 21, 2012 | 08:10 PM
coollooking96F350
OK, so I have dis-connected all the rear lights, front lights, ABS switch in the rear end. I have isolated it to the right side. Flasher went bad, when I installed a new one, left side blinked normally, right side blink like there is a short. Still blowing fuses. Is is possible that it could be the brake switch?
Anybody have ideas?
Old Aug 25, 2012 | 11:00 PM
madpogue's Avatar
madpogue
So it blows the fuse with the right turn signal even when both right-side bulbs are removed?
Old Aug 26, 2012 | 08:18 AM
Ken_C's Avatar
Ken_C
I have seen bulbs go bad in such a way that they cause a short...
msgntsu
28
Oct 17, 2008 08:20 PM
noobs
Electrical Systems/Wiring
Apr 17, 2006 09:30 AM
steamplant
Oct 27, 2005 08:17 AM
mikemonce
1997 - 2003 F150
Jul 1, 2004 06:00 PM
mikhett
Nov 18, 2003 07:59 PM
