Vibration Help
Old Nov 5, 2014 | 04:00 PM
endobear's Avatar
endobear
Vibration Help
The last couple of times Ive had the truck out on the highway I noticed a slight vibration that seems to be getting worse. Almost feels like I am running some super aggressive mudders. 1000-2000 rpm when Im going over 45 under a load.
I was thinking carrier bearing and or ujoints but replaced them all about 40,000 miles ago.
Could see a little grease on the end of the ujoint cups but didn't feel any play.
Old Nov 5, 2014 | 04:29 PM
Tugly's Avatar
Tugly
Double-check the bolts holding your driveline on each end. They sometimes work loose.
Old Nov 6, 2014 | 08:20 AM
endobear's Avatar
endobear
I will put a wrench to it tonight and give her a good grease job.
Old Nov 17, 2014 | 11:19 AM
endobear's Avatar
endobear
Update:
Everything was tight and good.
Pulled the shaft and the carrier bearing was a little easy to spin so took the shaft to a drive line shop.
It was determined it was time to replace all three joints, the carrier and balance.
Shaft was a little out but they said not terrible.
I only got about 50k out of my Moog joints but Im thinking that the carrier wasn't shimmed right and a poor maintenance on my joints caused them to wear early.Took about 1/2" of shims off of the carrier.
Truck is smooth as silk now.
jtfd93
Mar 9, 2018 10:01 AM
jakgod3
Jun 16, 2017 02:49 PM
Blown284
Jan 2, 2012 04:35 PM
kc0rey
13
Oct 3, 2009 09:42 AM
85 F-350CrewCab
Sep 12, 2004 11:00 PM
