Trans Pan Gasket
Old 07-08-2016, 02:32 PM
Jesse4's Avatar
Jesse4
Jesse4 is offline
Trailering
Trans Pan Gasket
1995 E350 motor home (cutaway) chassis w/ 90K mi, E4OD trans. Replaced trans fluid & filter (Wix), using rubber pan gasket supplied with filter. Included directions are to tighten to 80 inch-lbs in first pass, then 120 final pass. Using torque wrench (Craftsman 3/8” beam type, about 45 years old), I was finishing first pass when I noticed that the gasket had squished out about 3/16” around several bolts. Going to 120 was out of the question, so I took pan off and looked at gasket. It looked OK, with no indication of misalignment or any other problems, so I started again, this time using a 1/4” drive ratchet. I tightened it by hand in two passes, just snug and then until the gasket just bulged out a tiny bit, maybe 1/16". Is this tight enough? Could the torque wrench be in error? That much? Any other thoughts?
Old 07-08-2016, 03:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,614 Likes on 1,082 Posts
That gasket is going to leak. The original gasket is reusable many, many times and is FAR superior to the cheap junk that comes with the filters.
Old 07-08-2016, 04:50 PM
Jesse4's Avatar
Jesse4
Jesse4 is offline
Trailering
The previous gasket was cork and came apart upon removing the pan. I guess I'll go to Ford and get one. Fortunately, I haven't put fluid in yet and there is no rush to get it on the road. Thanks for the info.
Tyler.172
04-23-2014 04:57 PM
Grat123
07-13-2013 03:49 PM
jhaas63
11-21-2012 04:39 AM
99f350sd
06-07-2006 10:47 PM
54Guy
1978 - 1996 Big Bronco
09-24-2003 10:40 PM
Quick Reply: Trans Pan Gasket
