Reds Dead... Again!!!!
Old Jul 8, 2016 | 08:29 AM
Byrddog's Avatar
Byrddog
Ok, I need the gurus and thinkers on this 1 guys!!!
So, a couple weeks ago I blew a fuel line, (the top 1 on the FPR, that goes down behind the A/C pump).
So, I got it changed out no problem. However now, its dead!! Absolutely nothing... lights and guages all come on as does the radio and all other power equipment. However it will not crank for anything!!!
I've double and triple checked my work, there are not loose or disconnected wires (that I can see), batteries test good, starter tested good too, and can't find any blowin fuses....
I am at a loss, any ideas I may have missed?
Thanks in advance everyone.
Old Jul 8, 2016 | 08:50 AM
knottyrope's Avatar
knottyrope
Try starting in neutral?
Old Jul 8, 2016 | 09:39 AM
Byrddog's Avatar
Byrddog
Also replaced IPR and CPS recently, and it ran after those repairs...
Old Jul 8, 2016 | 09:40 AM
Byrddog's Avatar
Byrddog
Yes sir, I have....
Old Jul 8, 2016 | 09:44 AM
Byrddog's Avatar
Byrddog
Also the fuel bowl is completely empty (and not filling), would that cause this?
Old Jul 8, 2016 | 09:50 AM
cowmilker08's Avatar
cowmilker08
Unless you have e-fuel, no fuel moves until the engine turns.
With the truck in park, use a screw driver to short the big terminals of the solenoid on the passenger fender.
Old Jul 8, 2016 | 12:28 PM
knottyrope's Avatar
knottyrope
Dual tanks? Maybe when switching it didn't switch all the way.
No fuel in bowl if sucking air could be clogged FPR screen or broken suction line in tank if under 1/4 tank.
Old Jul 8, 2016 | 01:47 PM
cowmilker08
The problem is it wont crank.
Old Jul 8, 2016 | 01:51 PM
97-psd's Avatar
97-psd
I would try what cowmilker said. Jump the starter relay and see if you can get it to crank. It may just be coincidence that this has happened after the fuel line failed
Old Jul 8, 2016 | 05:07 PM
Byrddog's Avatar
Byrddog
I went as far as to put a new solenoid in it yesterday.
Old Jul 8, 2016 | 07:11 PM
powrstrkr's Avatar
powrstrkr
Maybe you don't have voltage to the primary side when you turn the key. If shorting it out gets it to crank that might tell you no voltage is getting to the primary when you turn the key but you'd have to check it with a volt meter. Did you track down a fuse for that yet?
Old Jul 8, 2016 | 08:12 PM
1994F2507.3L's Avatar
1994F2507.3L
I had the same problem. would really light up in the cab. No crank. Nothin. Stumped me for a bit. Removed and used a brush cleaner on battery terminals and cable ends, reinstalled and fired right off. Connections didn't look dirty but some how that did the trick.... Only happened that one time.
Old Jul 8, 2016 | 10:52 PM
BBslider001's Avatar
BBslider001
Yep...battery cables, connections, and grounds. If there is any white residue, you may not be getting power when you to crank. Clean and tighten them all, even if they look good. Trust me.
Old Jul 9, 2016 | 06:41 AM
97-psd's Avatar
97-psd
I understand you are desperately trying to get back on the road, but let's try to isolate the problem first, then replace parts as needed. Replacing suspect parts can make it difficult to find the source. Did you try jumping the solenoid first?
Old Jul 9, 2016 | 07:47 AM
krifenbu's Avatar
krifenbu
I want to ask if the truck is an automatic or manual transmission.
Thanks.
Kevin
