If head bolts stretched to cause problems wouldn't they still be stretched no matter under a load or not? I made a 200 mile run this past weekend unloaded pushed it harder than normal going up hill and when the strectch was clear pushed higher speeds and never saw temp rise above 200.
Coolant is GO-5. Has about 2000 miles on it. It only puked when temps went above 220-225 shouldn't it puke when it over heats? As soon as i can get my hands on the stuff needed to pressure test i will
I don't think coolant temps of 225 alone should be causing puking. That's not exactly "overheating".
As a structural engineer this is one of the few things I'm qualified to answer. I went into great depths on this answer a couple year's back on this forum. I'll try and not geek out this time.
The head bolts clamp the heads down. IH chose to stretch the bolts to yield (this the torque to yield, TTY, designating). This leaves very little reserve in the bolts to continue holding as compression builds in the cylinders. If you don't tension the bolts past yield, the bolts don't permanently stretch. Once the bolts go past yield, they permanently lengthen. We are talking microns here, not fractions of inches.
Once the bolts are microns longer, they are still clamping the head down, just not as tightly. Thus, they can run normal under light load, but as compression builds in the cylinders from heavy loading, the clamping force is offset just enough to allow some combustion gas blowby past the head gasket and into the coolant system.
As heat rises, metals (head bolts) become softer. This exacerbates the stretching. Under the constant load induced by towing, three engine Will inherently run hotter. 10 to 15 degrees hotter when towing is normal.
So both temperature and compression are higher when towing. I know there are some that will argue that the compression is the same, but in a dynamic load situation, it's not because the cylinders are much harder to push down from the combustion while towing.
Temps got up to 232 ect. Fan seems to be coming on i can hear it. Normal driving ect at 191-193. Towing 206-209. Its when i go up and incline or put a load on engine. Once it hits 220 it pukes out degas bottle. I have the mishi radiator. And yes i have plastic impeller water pump
Well that could be a factor. Been seeing something about that causing overheating.
One more questing for you, How full are you filling the degas bottle to?
If you over the new full point it can vent on you when heated.
If it's an old bottle without the new mark on the tank then just below
the low line is about where you want to be.
I'd run a second gauge first just to see. I noticed the gauge said made in China. That's just what I would do. On a second note, my sons truck dose have head studs but still gets to 230 ect and 247 eot. All BPD stuff. Remote oil cooler also. He dose not pluck coolant. I think we have his figured out but won't know till end of September when he towing his 16K trailer home.
Unloaded took a while had to put alot of boost to get it to climp but it actually got up to 18-20psi. Guess ill be doin heads
Sorry to hear that,but it looked that way all along. Proper coolant level, new cap, egr delete and still gets to 18 psi without overheating .... 99% chance it's a head job
You can drive it at 16lbs, just ck the water level,make sure you can see some in the bottom of the coolant tank,dont overfill because it will puke it out to the level it wants anyway, new cap every mnth, anti freeze to keep boiling down, dont build over 20 boost when towing.
Down shifting while going up hill helps cooling too. The engine works LESS believe it or not. It also helps coolant circulation. It kills the fuel economy thou.
