Hey everyone new to this forum and would like some assistance . thanks in advance.so I got an 02 7.3 with 201k and it will not start with the key I can use the wire to jump it and ran fine so I I came to the conclusion it was the neutral safety swith so I replaced it and still no start and now when I'm driving it it's acting like it's jumping into neutral then going down a gear.and this was not an issue before I changed the switch.
What do you mean by indexed? I believe I have everything on it lined up properly.the wire on the passenger side that unclips.if you run a wire from that to positive terminal truck will start.thanks for the reply.
