Lets talk Real time scanners
Old Jul 7, 2016 | 12:30 PM
Ezalycasaid's Avatar
Im wanting to get a scanner for my truck. I want to be able to monitor EVERYTHING in my truck as its running. I was looking into getting a Snap-on MT2500. I was gonna use the OBD11 Adaptor with the Primary cartridge Domestic Combination thru 99. With the K-2 key and K-2a key. Is this right or do I need the fast track trouble shooter? What other scanners can I use and what does the fast track do, and what does the primary cartridge do? If I go another route what is out there and what would I need with it?
Old Jul 7, 2016 | 01:30 PM
fordpride's Avatar
fordpride
AutoEnginuity Enhanced Ford Expansion - Riffraff Diesel Performance
Old Jul 7, 2016 | 01:50 PM
Ezalycasaid
Im very confuzd on the expansion pack thing. Do I need a scanner to add the exansion pack to? Do I just use a computer? It says it only works on SD 7.3.
Old Jul 7, 2016 | 03:49 PM
z31freakify's Avatar
z31freakify
It says that because some of our earlier models 7.3 has to have the pcm reflashed to accept obd readings.
Old Jul 7, 2016 | 04:05 PM
Ezalycasaid
My engine was built in 8 of 97 would I have an older pcm or a newer one
Old Jul 7, 2016 | 04:47 PM
z31freakify
Not sure what year they came with obd compatibility. Maybe someone with more knowledge will chime in.
Old Jul 7, 2016 | 07:49 PM
oldbird1965's Avatar
oldbird1965
I use AE on mine, reads it just fine on my laptop. It can do data logs in printable versions.
Old Jul 7, 2016 | 08:09 PM
fordpride's Avatar
fordpride
Just need a laptop
9 times out of 10 the OBS has already been flashed. If you took a 94.5-95 into the dealer for work they would just flash it to make their lives a little easier
Old Jul 8, 2016 | 11:10 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Sorry to butt in but I have a question also. What would be the advantage to getting the total Ford enhanced bundle, which is $360?
Old Jul 8, 2016 | 01:52 PM
madMatador78's Avatar
madMatador78
Why not use and Android tablet and torque pro?
Edit: here's the link
https://www.ford-trucks.com/forums/1...werstroke.html
Old Jul 8, 2016 | 04:32 PM
97-psd's Avatar
97-psd
nothing says you can't use Torque. I just don't think it made it to the list yet.
Old Jul 8, 2016 | 07:39 PM
Ezalycasaid
I have torque pro. With the blue obd11 dongle. I can get rpms and speedo wit it. That's it.
Old Jul 8, 2016 | 10:06 PM
LeoJr's Avatar
LeoJr
I like my Aeroforce interceptor mounted full time on my steering column. I believe it will display every sensor the OBS computer looks at, two at a time, reads and clears codes, and does the injector contribution test. Apologies for no picture.
Old Jul 9, 2016 | 07:15 AM
oldbird1965
Aeroforce can read two at a time up to eight in rotation.
Aeroforce Technology Inc | Products - Interceptor
Old Jul 9, 2016 | 07:50 AM
madMatador78
You have to enable the Ford protocols to get the other gauges. It's a little difficult to set up I'll admit but once you get it, its pretty slick.
