Clutch problems?
Old Jul 7, 2016 | 11:12 AM
85idipower's Avatar
85idipower
Clutch problems?
I put a new clutch in my truck. Then it wouldn't start and had to replace my distributor and after I re timed it it won't climb hills. It does OK on flats and down hills it just takes a little more gas then usual but it doesn't go up hills. I revved it up to around 3,000 rpm and let the clutch out on the base of a hill but the truck just stalled out. So if the clutch isn't slipping what is it? I'm really lost and getting fed up. It's a 1994 ford f150 4x4 5.0l with the m5od 5 speed
Old Jul 7, 2016 | 11:18 AM
rla2005's Avatar
rla2005
Did you pull the SPOUT plug when you set the base timing? If you left it in then you have severely retarded the timing which results in low power as you described.
For reference: How to set the timing on an EFI Ford
Old Jul 7, 2016 | 11:22 AM
85idipower's Avatar
85idipower
Yeah I disconnected it. I'll try re timing it again but I don't think its that.
Old Jul 7, 2016 | 11:53 AM
rla2005's Avatar
rla2005
Be sure the timing gets set to 10 BTDC or a little more. Use the guide I posted before to ensure you are using the correct pointer. The other possibility is a slipped outer hub on the balancer, that will throw off the true base timing.
Old Jul 9, 2016 | 08:14 AM
Mudsport96's Avatar
Mudsport96
locating tdc
Scroll down to the tdc indicator section and read.
I made one out of an old spark plug. Turned out my balancer had slipped and the timing marks are wrong. So timing it to where the balancer shows 14 degrees was really closer to zero. The performance was aweful. This MAY be the case for you as well.
laptopjockey
Mar 28, 2018 04:45 AM
bzerk56
Jan 13, 2017 12:45 PM
fordfan302
Apr 16, 2008 09:57 PM
FatBrian
Mar 6, 2007 06:46 PM
fordmanSLO
Nov 12, 2001 10:43 PM
