hottttt
Old Jan 7, 2017 | 08:24 PM
bzerk56's Avatar
bzerk56
hottttt
what causes red hot header tubes
Old Jan 7, 2017 | 08:26 PM
49fordv8f4's Avatar
49fordv8f4
Engine running too lean. Or retarded ignition timing.
Mark
Old Jan 7, 2017 | 09:10 PM
bzerk56's Avatar
bzerk56
ok kinda figured as much with the timing , whew dont need any more lol gotta get my clutch bled first then dial things in , thanks
Old Jan 10, 2017 | 04:31 PM
petemcl's Avatar
petemcl
What engine? Mods? Use? A little more info please or we will just be guessing.
Old Jan 10, 2017 | 07:53 PM
Drewski 2's Avatar
Drewski 2
Back in the 60's while taking an auto-diesel class, we had an engine running on a dyno. The instructor turned out the lights, telling us to watch the cast iron exhaust manifolds. We saw them start glow bright orange and then nothing and then orange again. We watched this repeated several times...... the instructor was retarding the timing and returning to normal timing. Retarded timing will definitely heat up your exhaust headers.
Old Jan 10, 2017 | 09:17 PM
bzerk56's Avatar
bzerk56
aha i kinda figured that was it ! n petemcl its a 56 with a 5.0 and a 5 speed just installed
Old Jan 13, 2017 | 12:45 PM
petemcl's Avatar
petemcl
That might be normal. Modern engines run much hotter combustion temperatures than our old flatheads. If you are driving at highway speeds for some time with any kind of a load that would be normal. But at idle then timing and mixture as previously suggested would be the most obvious causes. If both are correct then a vacuum leak: cracked hose, ruptured brake booster diaphragm, missing PCV valve, intake manifold gasket, carb base gasket, etc.
The Terrible Blob
13
Feb 1, 2014 08:00 PM
tygerrrr
Aug 29, 2009 02:01 AM
The67Beast
Jul 7, 2006 08:11 AM
M04
Jan 1, 2005 08:20 AM
