Cross Member Replacement
Old Jul 6, 2016 | 06:35 PM
fishfreak101's Avatar
fishfreak101
So I got the bed off of my 97' F-250, and the frame itself isn't bad but there is some noticeable rot on the crossmember. It is obvious that the crossmember needs repair but how do I go about doing this its this something that I just can pickup at a scrapyard, and what is the easiest way to do this. This is my first truck I'm 15 so any help is appreciated.
I made the decision to replace my front gas tank and it was obviously a good one because there ended up being some holes in the tank, but I am unsure if the rear tank needs replacing. It seems solid but would replacing it now be worth it.
http://cimg6.ibsrv.net/gimg/www.ford...3cb676be22.jpg
Old Jul 6, 2016 | 08:19 PM
Diesel_Brad's Avatar
Diesel_Brad
Pretty much the same cross member from 1980-1997 F150-F350
Grind the rivets off, punch them out. Then bolt in new cross member with 1/2" grade 8 hardware with flat washers and lock nuts
Old Jul 26, 2016 | 08:38 PM
fishfreak101
Thanks for the response. I got the rotted cross member off do you hapen to know where I can find a replacement?
Old Jul 26, 2016 | 08:50 PM
Diesel_Brad
Pretty much any junk yard that has these trucks
Old Jul 26, 2016 | 08:51 PM
fishfreak101
Alright thanks
armyaviation
Feb 2, 2017 06:31 PM
bigfoot22
Mar 1, 2010 12:21 PM
Big Red
Jan 15, 2006 10:47 PM
learpilot
Sep 16, 2004 10:32 AM
jniolon
Jun 24, 2004 03:14 PM
