Sorta newbie question, my truck will start up but when it does it takes awhile for it to go. I recently changed out my fuel filters and I when I did all the pre starts as in on for 3 on off 15. It started up rather quickly like was almost brand new to an extent. Just trying to get a better understanding of what can to do ease the problem or completely get rid of the issue.
Yes it's my first time doing it myself but like its a problem well not a problem because truck starts up but it was doing this even before switched out the filters
Sometimes the
"O" ring on the caps gets twisted. If you did not use OEM filters it my not be pressing on the valve inside the secondary filter on the engine to let enough fuel in or out? Without a set of gauges it's really hard to tell much more. I would reinstall both filters and be sure to lube "O" ring.
Ok thank you I'll look into that and now with getting an OEM filters is there any place special I need to go to get them or do most any place carry them
JoshuaBow. If that doesn't do it. Come back but you really need a way for us to tell what all is going on like scan gauge ,dash boss ,or forscan. Or toquepro
