06 fuel line fitting connection
Old Jul 5, 2016 | 07:58 PM
MN_Andy's Avatar
MN_Andy
I searched and didn't find a post similar to what I"m looking for. I'm in the process of removing my intake manifold and when I disconnected the fuel lines at the secondary filter housing the largest fitting and line twisted before the compression nut broke free. If I remember right the fitting needed a 13/16" & 7/8" wrenches to loosen, it's also the fitting that goes into the cover for the blue spring upgrade. The other fittings were smaller wrench sizes.
So I picked up that replacement of damaged fuel line today with my new Oil cooler kit and when I looked at the fuel line end that goes down around the driver side cylinder head has a end for different kind of fitting I'm not familiar with. I guess I need some special tool but it's not obvious to me what I need for a tool or the process of disconnecting it?
Can any one help me out?
Old Jul 5, 2016 | 09:07 PM
163junk's Avatar
163junk
Sound like the fuel supply tube and the bottom end is a spring lock fuel line, you can buy a disconnect tool for about 10 bucks at most part stores.
Old Jul 6, 2016 | 09:53 PM
MN_Andy's Avatar
MN_Andy
Ok I'll look for that line disconnect tool set. Thanks for the info!
rawdeal
Feb 8, 2025 01:42 AM
Macmathews
Jul 13, 2016 08:19 PM
rob8210
1997 - 2003 F150
Feb 18, 2013 03:52 PM
neevnav
Mar 27, 2007 10:59 PM
VIKING24
May 19, 2005 07:50 PM
