EEC-IV Issues, Fried??
Old Jul 6, 2016 | 05:49 PM
Lead Head's Avatar
Lead Head
Just because the cruise works doesn't mean the PSOM is 100% fine. The cruise control module itself is known for causing issues as well. I'd try unplugging the cruise control.
Old Jul 6, 2016 | 05:56 PM
Imleadguitar's Avatar
Imleadguitar
I did all my tests with it unplugged to eliminate it. The abs to. I've got the step by step from Ford on how to test. I can recite ohm requirements for every system related to this issue. The only thing, to my frustration, that I can't find how to test is the pcm. The only test available is an actual voltage test which makes no sense because it's testing the psom feeds. But I did it anyway and it indicates a bad pcm but the Ford tech at the dealership did the same test with the same outcome and it turned out a pin wasn't making good contact. All in all the pcm is the only part I can logically question anymore...just wish I could find more info on it.
jimjokjv
37
Sep 26, 2017 09:50 AM
farmdad
Nov 20, 2014 09:41 AM
cjgray1974
18
May 20, 2014 03:17 PM
jv2290
20
Jan 15, 2013 05:11 PM
brooksbronco17
Mar 3, 2010 08:48 PM
