Sponsored by: Real Truck
Preventing Rust On Bed Sides
Old Jul 6, 2016 | 01:48 PM
sammy77's Avatar
sammy77
Well, it's a very common issue, and it is caused by a "foam" that is behind the wheel well where the pan meets the quarter panel. This foam retains the moisture/road salt, and causes the rust so many trucks see.
On my '05, I completely removed the foam, replaced the roll pans on both sides, painted everything in POR-15, then rhino lined it all. Then I added wheel well liners, to prevent as much stuff getting sprayed back up as possible. Seven years later, not a speck of rust there. Including a few years of snowplowing after the repair.
OCD you say...? lol
Old Jul 6, 2016 | 03:27 PM
kcducttaper's Avatar
kcducttaper
I've thought about ripping my foam out and bed lining it up and slapping some wheel well liners in there. Maybe doing a yearly application of Krown on top of it too.
I just can't figure out why the foam thing is in there to begin with. It's an extra manufacturing expense, so there has to be some reason they put it there.... Just can't figure out what the heck it's for.
Old Jul 6, 2016 | 03:55 PM
GN1220's Avatar
GN1220
Is there access to the foam to remove it? Seems like that should be priority number one.
Old Jul 6, 2016 | 04:45 PM
SteveH-CO's Avatar
SteveH-CO
I could not get my hand up there to remove the foam, and it seemed to be crimped into the inner/outer fender joint. If anyone has removed all of the foam, they should explain how, in detail.
I ended up drilling a few small holes in the inner bed over the wheel well, and pumping in ATF from a pump oil can, until it was running out of both ends of the wheel well. I let it drip on newspaper for a couple days. I have confidence that the foam in there soaked up all the ATF it could.
Old Jul 6, 2016 | 05:29 PM
ProjectTriton's Avatar
ProjectTriton
The reason ford put the foam in the wheel wells was for sound deadening purposes... I'm leaving the foam out when I replace my wheel arches in a week or two... but like the other guys said a coating of some time should work well along with wheel liners....As for pulling the foam out somehow good luck.. I just tried pulling on what I could thru a hole in my wheel arch and the foam just stretched and broke... so taking it out as one piece wont happen. maybe(idk) but maybe there is a chemical that would dissolve the foam.. I know you could burn it out but then you risk messing up your paint job on the outside.... well anyway good luck to ya....
Old Jul 6, 2016 | 06:02 PM
sammy77's Avatar
sammy77
I had everything cut out, and replaced the skins of the bed sides. When the roll pans were removed, you're able to access, and remove all of the foam.
Old Jul 6, 2016 | 07:16 PM
GN1220's Avatar
GN1220
Brake cleaner dissolves foam I believe......
Old Jul 7, 2016 | 09:32 AM
droldsmorland's Avatar
droldsmorland
I like sammy77s idea...Cutting out the inners and welding in new is about the only way to do it properly...unlike OEM. Should I need to do this on a new 50-60+K truck? NO...But the next new new one will get this treatment. That is unless Henry decides to eliminate this CRAP after 15 years. Noise abatement CRAP! It sells new trucks and pizzes me off. A sponge in a 4x4 wheel well, good job, fine engineering practice...This one was bean-counter driven for sure.
sportscar
May 13, 2019 03:11 PM
1968 F100 Ranger
Jun 8, 2012 10:48 AM
The assassin Blevins
Nov 20, 2009 10:49 PM
Dan McGrew
Paint & Bodywork
Nov 17, 2005 01:59 PM
Bill'sBoy
Paint & Bodywork
Jun 23, 2005 01:13 AM
