Bed Mounts
Old Aug 21, 2003 | 09:38 PM
airharley's Avatar
airharley
Bed Mounts
the take to fire comment came about when he showed me where he replaced his front engine mount bushings with the pucks.
Old Aug 22, 2003 | 09:51 PM
mwc4275's Avatar
mwc4275
Bed Mounts
My bed sits up about 3/4-1" higher than the frame rail, you can see a gap between them, almost similar to a small body lift. So probably the best thing to do would be to make some up out of some oak then huh???
Old Aug 25, 2003 | 11:59 PM
1966ford's Avatar
1966ford
Bed Mounts
The ones under my box are wood as well.
Old Aug 26, 2003 | 12:16 AM
6t6merc's Avatar
6t6merc
Bed Mounts
Mitch, let me know if you need the dimensions.
Eric
Old Aug 29, 2003 | 10:33 PM
mwc4275's Avatar
mwc4275
Bed Mounts
Yeah the dimensions would be great. Thanks.
Old Aug 29, 2003 | 11:58 PM
arnolan's Avatar
arnolan
Bed Mounts
But where can you buy them, if possible?
Old Sep 1, 2003 | 10:58 AM
6t6merc's Avatar
6t6merc
Bed Mounts
I found my spare. Sorry I took so long. The blocks my friend made are oak, as were the originals. He laminated two 1x2" pieces lengthwise and then cut them to size.
The dimensions are:
L: 3"
W: 2"
H: 1 5/8"
The two top edges are bevelled to a width of 1/4". You will see how the bevel allows the blocks to fit snugly into the cross sill. I installed mine with a rubber hammer. Hope this helps.
Eric
Old Sep 1, 2003 | 11:05 AM
johnsalterego's Avatar
johnsalterego
Bed Mounts
Wow - that does look awfully close to a hocky puck; It wouldn't be all that tough to shape one down to those dimensions. I like that idea a lot better than using wood, even if it is what was in there originally. A lot has changed in 40 years...
diablodude64
13
Mar 30, 2012 05:19 PM
4inchlovin
N. California Chapter
Sep 9, 2011 06:55 AM
82ford302
Jan 13, 2010 03:40 PM
cptslewis
2004 - 2008 F150
Mar 13, 2006 10:36 AM
