What part do I order?
Old Jul 3, 2016 | 08:32 AM
HH1492's Avatar
HH1492
I have a 1991 f150 4.9 5 speed 2 wheel drive. I was preparing to replace my u-joints and noticed the transmission output shaft seal boot (I believe boot is the correct term) is torn. Looking up parts, I cannot find s seal listed for a 5 speed that has a boot. I have attached pictures of my transmission tag and one of the boot. I am not the original owner so I am uncertain if anything was replaced in the past. I have searched Motorcraft, Advance Auto, and Rockauto.
Name:  f150 trans data.JPG
Name:  f150 trans data2.JPG
Old Jul 3, 2016 | 08:34 AM
HH1492's Avatar
HH1492
Oops. I don't know why the picture orientation is upside down.
Old Jul 3, 2016 | 08:39 AM
Rudiak's Avatar
Rudiak
Try Southern Gear.
Old Jul 3, 2016 | 08:56 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Local auto parts store should be able to get you an output shaft seal for you. It looks be be a M5OD-R2 transmission
Lead Head's Avatar
Lead Head
Interesting, the only seals on RockAuto with the boot are for the T18 4speed. You might have to go to a dealer to see what's going on.
Old Jul 3, 2016 | 09:11 AM
My4Fordtrucks
I saw that too. It's possible it was replaced with the wrong seal.
Old Jul 3, 2016 | 09:20 AM
roboto65's Avatar
roboto65
I know it's not but kinda looks like a AOD seal. So maybe the wrong one got put on by PO
Old Jul 3, 2016 | 07:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You have an iPhone, don't you????
Seal shouldn't be a problem to find.
What brand or store do you want?
Old Jul 5, 2016 | 08:49 PM
HH1492's Avatar
HH1492
Thanks for the information. I believe it is the wrong seal. Will order the correct one. And ArdWrknTrk, I do have an iPhone. Do I need to upload pictures a different way next time? Or just "head space and timing issue" on my part?
Old Jul 6, 2016 | 08:40 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's been an issue since iOS 5.
Metadata in the image file causes the picture to display inverted when shared with anything but an Apple iOS device.
I don't have an easy answer to why it doesn't 'just work'
My comment wasn't meant as a dig at you, or anything other than an observation, in reply to you asking why your pictures were upside down.
(I'm going to edit this to iOS device, since the poster below me said it doesn't appear correctly on his iMac)
Old Jul 7, 2016 | 08:46 PM
HH1492's Avatar
HH1492
Your response was not taken as a dig at me. Just wanting to learn. I have been using this site since early 2011. I really enjoy working on my vehicles.
Old Jul 7, 2016 | 10:11 PM
My4Fordtrucks
Ha, interesting. I had assumed that you went back and fixed the pictures because up until now i had been seeing them on my phone. It apparently does not fix the orientation and turn them right side up on an iMac.
Old Jul 8, 2016 | 06:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F1TA-HA = 1991 F150/250 2WD - Mazda R2 5 Speed Manual Transmission.
E8TZ-7052-C .. Output Shaft Seal - Use with F1TA-FA & HA
Old Jul 8, 2016 | 08:16 PM
HH1492's Avatar
HH1492
.Just to satisfy my curiosity, I did an internet search for that part number (E8TZ-7052-C) and found it at Rockauto for a 1989 f150 with Mazda 5 speed. Kind of upsets me that I could have ordered the wrong part. I will be ordering a Motorcraft part this weekend. Thanks NumberDummy
dieselsubmariner
Apr 1, 2026 09:11 PM
F-250 restorer
Oct 2, 2018 04:04 PM
petritl
Sep 25, 2017 12:15 AM
hooler1
May 16, 2011 05:38 PM
