Everything's dead
Old Aug 17, 2003 | 06:45 PM
FORDYDAYS's Avatar
FORDYDAYS
Everything's dead
Just had starting problem with my '87 351. I thought I had narrowed down to solenoid, replaced it, and this happened:
Third time I started the truck, the starter kept running, even after shutting off ignition switch! I finally got the battery unhooked, figured I had gotten a bad solenoid. Traded that one in, then I charged/checked battery, it was good and charged up. Put new solenoid in and now I have nothing, as Klink would say...NUTTING! Not even any lights.
I looked at fuses, they are ok but nothing works. Did I blow a fusable link or something...HELP!
Old Aug 17, 2003 | 07:18 PM
Bob Ayers's Avatar
Bob Ayers
Everything's dead
Welcome to FTE!!!!
Fuseable links could be the problem, but I would check / clean
your battery cables good first.
Old Aug 17, 2003 | 08:14 PM
Mil1ion's Avatar
Mil1ion
Everything's dead
How long has the engine been sitting around doing nothing?
Old Aug 18, 2003 | 10:09 AM
FORDYDAYS's Avatar
FORDYDAYS
Everything's dead
Thanks for the welcome...
I just drove it the other day, after putting on the new solenoid. It is sort of a once a week driver.
For the last few weeks, it had had a problem starting...might start...might not. Then I put the solenoid on. It started fine two times, and now have this new set of problems.
Old Aug 18, 2003 | 12:26 PM
HomerWinzlow's Avatar
HomerWinzlow
Everything's dead
You may have burned one of the fusable links that wire to the starter relay, or simply missed one and its not connected or on the wrong post. I have seen some aftermarket starter relays, and even some factory motorcraft that you had to wire opposite of the original, or the relay would stick after a couple uses.. Long ago there was a service message about this. It was so common a problem that when I replace one on a late 80s or early 90s model, I leave the negative cable loose enough to pull it off and start it about 10 times before I secure the cable.
Old Aug 18, 2003 | 01:45 PM
FORDYDAYS's Avatar
FORDYDAYS
Everything's dead
I wired it up just like the one that was on it. I didn't read the instructions on the new one, maybe I should look at them.
Am I thinking correctly that I can do an ohms test on those fusable links? I have checked about five of them that are in close proximity to the solenoid, and there is no resistance.
I am very interested in what you mention about having to wire the solenoid backwards...I will check that out. Do you know if you wire it like I did and that starter stays on...do you burn up anything in doing so?
Any help apprecieated, Bob
Old Aug 18, 2003 | 02:05 PM
HomerWinzlow
Everything's dead
Just check for 12V on the fusable links at the harness end of the link with the battery connected. If the relay sticks long enough it could burn up the starter, and weld the relay in the engaged position.
Jordan Edwards
Dec 6, 2016 09:15 PM
cityjack
Mar 27, 2016 07:45 PM
FordRv1981
17
Sep 11, 2015 10:07 AM
Andysutt
1978 - 1996 Big Bronco
Jul 18, 2003 02:26 PM
iggs43
May 22, 2003 03:34 AM
