Solenoid Problem
Its also possible the switch engaging the solenoid has developed a short leading to the constant "on" condition. Check it for positive make and break action; don't want to install a new part only to have to fail due a bad start switch.
It being a start-only solenoid it probably isn't necessary to install a continuous duty type. Do use a good brand though---I prefer NAPA's better quality line, your budget might dictate otherwise.
Let us know what you discover---could be helpful to someone else down the line.
Thanks for responding. The solenoid is not original and is about three years old. I replaced it when I got the RV at that time because it had the original then and I also replaced the other solenoid as well. I was advised that I could use a NAPA ST85 solenoid, but I will check out what you advised to do. Don't want to spend on that solenoid and then have it melt down too. Thanks again.
Please let us know what you eventually discover---I don't think we've had this or even a similar issue since I've been here. Any info you could add might be helpful down the road to another E-Series RV owner.
From someone who stated that where he works they have replaced the solenoids on vehicles with this type because of their heavy duty function. He stated that they are listed as working on Dodge vehicles, but in the literature on NAPA online it states that they can be used on golf carts and RVs. I was not going to install it unless I ran it by others on the forum to see if anyone had any info. You may look it up on the NAPA online and see what it states and let me know what you think. Thanks for responding.
Not really sure why it has an RV designation---use and/or duty cycle would be the most important aspects to compare.
Remember if your RV and the generator sit idle for long periods of time you could possibly experience this again, even with the new part.
Also make sure the interior Gen Start switch is opening and closing with the toggle or rocker actuator---we discussed that earlier on.
Let us know how this works out!
From what your writing, you might have just got a bad after market solenoid to start with *pun intended*
One way to "check" a solenoid is to ark the two posts with a screwdriver, if the item starts, then you know the solenoid is bad, but you wrote that is melted down, and it might be a good idea to check the source of that, you could have a bad ground, or a bad positive cable causing over load on the voltage, which caused the melt down.
One solenoids ties the two batteries together while engine running to charge them, but isolates the batteries when engine stopped so engine battery not depleted. Second solenoid is an emergency one that will tie both batteries together if chassis battery dead. Mine also has 40 amp circuit breakers protecting these circuits, but again generator feed wired direct
I know you said that you might be going someplace to have this checked out.
I was researching something on my van, and I came across this......
What that solenoid is, or should be is actually an duel battery relay, or Battery Isolation Solenoid, and you should have a volt rating higher than a standard solenoid, like 200 volts.
That could be causing the melt down, as your just have a standard solenoid in place, and upgrading to the higher voltage Isolation Solenoid, where the alternator is charging both battery's at the same time, direct current at all times, is causing the melt down.
If your generator is not starting, it could be that the aux battery is not charged from the alternator, because the voltage is not getting to it thru the bad solenoid.
The solenoid on the passenger fender is for cranking the RV engine (460 or 351).
The solenoid on the drivers side is for tying the two batteries together for charging as you drive.
The generator is wired right to AUX battery and has its own starting solenoid at the generator.
The generator may have a starter or it may use its winding for cranking.
If it uses its winding for cranking you may have a brush problem. If this is the case you need to take the brushes out and measure them and replace them if necessary.
What model generator do you have?
If it is an Onan model BFA it does not have a starter.
Will check other things out on the RV as time and the weather allows. Thanks to all again fir their input.
