Noted above was the comment that white smoke was unburned fuel on a diesel. Is that correct? I was under the impression that white meant oil burning and black meant unburnt fuel, or is that only for gas?
Hi pwitort,
When I fire it up in the morning I always get a puff of white smoke, I believe this is normal.
When I get on it it pours out black smoke, that's all the unburned fuel it cant swallow up.Blue smoke would probably mean you're burning oil.
I thought the white smoke when first started up was from the oil that leaked down the valve guides overnite.
I recall that putting diesel fuel in a gas engine carburetor ( to clean the valves) produced large amounts of white smoke (unburnt fuel?)... so what does white smoke mean for a diesel...is it oil or diesel?
It's definately diesel fuel, oil would'nt burn white.It usually happens when you first fire it up in the morning.
Unplug the wires going to the glow plugs and try to cranck it, you'll see huge clouds of white smoke pouring out, unburned diesel fuel that has gone under compression but has not fired.
Magic
I was told that unburned diesel comes as black smoke out of the pipe (the reason of huge black smoke under full throttle), white smoke comes from water or moistness and blue smoke comes from burned oil.
