Essentialube
Old Jun 28, 2016 | 08:38 PM
jswartz84's Avatar
jswartz84
Essentialube
Anybody ever use essentialube in their 6.0 oil or fuel?
A quick search only pulled up one thread.
Old Jun 28, 2016 | 09:35 PM
87crewdually's Avatar
87crewdually
Never heard of it and probably will never use it in my diesel fuel. It said disperses moisture. I want moisture to stay together so the HFCM filter can catch and hold it so i can dra in it off. If that stuff breaks up the water so it passes through the filter onto the injectors it may damage the injectors, specifically the tips.
Old Jun 28, 2016 | 10:06 PM
jswartz84's Avatar
jswartz84
I wouldn't use it in the fuel either. I was thinking more for an oil additive. I bought it for my old truck to treat the oil, after sitting for 5 years I have a slight lifter tick.
Anyhow, I picked it up from a local diesel shop and they swear by the stuff. I also remember a long time ago the old timers used it in everything.
It says it helps a ton of things including removes varnish. I figured it might help with stiction?? I don't know and I've never had a stiction problem either.
Just wondering if anybody else has ever used it.
Old Jun 28, 2016 | 10:36 PM
HT32BSX115's Avatar
HT32BSX115
Most places that sell snake oils "Swear by it".........They're the ones making money by selling it!
Engine manufacturers usually never condone oil (or fuel) additives in their engines except maybe anti-gel fuel additives used on NON-winterized fuel etc.....
If it is determined by a Cummins dealer or distributor that use of a non-Cummins product has
caused a failure during the Cummins warranty period, then the repair of that failure would not be
covered by Cummins warranty.
Mack Trucks, Inc., neither recognizes nor recommends the use of any fuel additives. We do allow
a maximum of 5% bio-diesel fuel to be blended
with regular diesel fuel for use in our engines
There are many different types of fuel additives that are available to use. Caterpillar does not
generally recommend the use of fuel additives.
Seems that the additives are generally recommended by the people that sell them.
Not so much by the OEM engine manufacturers.
Old Jun 28, 2016 | 11:06 PM
diesel_dan's Avatar
diesel_dan
Deleted...
Looks kinda like Seafoam, use-it-anywhere stuff
Old Jun 28, 2016 | 11:51 PM
HT32BSX115's Avatar
HT32BSX115
Originally Posted by diesel_dan
Deleted...
Seafoam is pretty good for starting your woodstove!
Old Nov 18, 2016 | 09:48 PM
jswartz84's Avatar
jswartz84
Well, after about 1000 miles with this stuff mixed in the oil in my old 302, no more lifter tick.
A buddy of mine used it in his 6.0 for stiction and it worked well. He said he had tried archoil and revx and neither worked.
Just figured I'd give a little update.
Old Nov 19, 2016 | 09:21 AM
69cj's Avatar
69cj
For sticky lifters we used to use Marvel Mystery Oil. Worked great and cleaned the crankcase up also.
Dieseloholic1
18
May 22, 2018 09:41 AM
Fordtrucer
29
Feb 29, 2016 11:55 AM
6.0superduty
Jan 1, 2008 03:30 PM
goodie350
33
Apr 23, 2007 08:37 PM
skuteman
Jun 1, 2006 12:26 PM
