Overheated her this weekend, need recommendations
on
I overheated on my trip to Maine last month. The fan wasn't plugged in and I was a total of 22,300lbs going down the road. Coolant got to 255 and Oil to 265. Just to be safe I am flushing everything and replacing the degas bottle cap.
Oh...and making sure the damn fan is plugged in before future drives.....
Sounds like a typical busted coolant hose causing an overheat situation due to loss of coolant. The green coolant ans new wye pipe got you going. Replace the green coolant properly and continue to monitor things closely to make sure they was no collateral damage. Other than that just keep enjoying the truck.
Exactly^^. Don't throw the baby out with the wash water. She overheated and you corrected the problem. Do your fluid changes as planned and keep an eye on her just like you used to. If something pops up then correct it. By the way, I have seen some metal tubing "Y"s at the auto stores.
Millinex
26
02-16-2019 12:20 PM
