Trim tag decode
This PDF demo of the 61 shop manual should help you out. Might take a bit to load. Page 5 starts the ID info.
http://www.forelpublishing.com/demo/Demo20061.pdf
Warranty Plate decode.
When the post is quoted, the pic of the Warranty Plate disappears.
F11 = F100 4WD
C = 292 2V
K = Kansas City MO Assembly Plant.
132579 = 1961, assembled January 1961.
120" Wheelbase.
A = Raven Black.
F113 = F100 4WD .. 5,600 lbs. GVWR
FA = Borg Warner T-98 4 Speed Manual Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / 3,300 lbs. Rear Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
3302 = Domestic Special Order number, truck special ordered by the original purchaser, not "bought off the lot."
Originally Posted by Bulldog90
Warranty Number: F11CK132579 / WB: 120 / COLOR: A / MODEL: F113 / TRANS: FA / AXLE: 12 / MAX GVW LBS: 5600 / CERT NET HP: 135 / RPM: 3800 / DSO: 3302
C = 292 2V
120" Wheelbase.
A = Raven Black.
Bill, that will happen to pictures "attached" thru the FTE software, when a person uploads a pic directly to a post.
If a picture is hosted somewhere else, then it will show up in a quoted post.
So, say for instance you use Photobucket like I do. When someone quotes a post with a link to a picture that is hosted outside of FTE, then that link will also be quoted, and the picture will show.
Pictures attached to a specific post via the FTE software feature will not show up in a quoted post.
Stewart
Stewart
Stewart
Stewart
The only pic I've ever posted on FTE was just after SteveBricks died. It was taken of Steve & I at BJ's Brewhouse by ctubutis.
Thank you again for all the feedback. I made an offer on the truck but we are 2K apart so we will see what happens. Solid truck - was painted a brown metallic and rust was repaired at that time - frame looks good but as far as the owner knows engine has never been rebuilt nor has any of the rest of the driveline - so 5,000 seems right to me
Kuttawa07
05-08-2013 11:45 AM
jowilker
02-08-2002 07:38 PM
