I have a RABS II so I don't know if this all works.
I tried to push the float down. I don't know where it is but pushing down with the cap off the res, did nothing. is it easy or did i need a pointy small item? It feels like there is a cage to keep it from moving??? Perhaps this is the problem. I don't have any rear brakes So i will try and bleed them tomorrow. the fluid in the res looks very dirty too. Not sure why ? mix of colors? I have clear new fluid and only have seen clear. I like to know what is wrong before I start replacing everything...
New brake lines and the rusted out thing under the driver door in the frame. I need to know how to test master or get new res.
There should be a float in the brake fluid resivor. Mine was sticking down and I had to work it up and down some to get it to move freely. I could push it down with my finger but had to use a pick to lift it back up.
When it is down at the bottom it should signal the red brake warning light in the cluster to come on.
Dang, well hopefully all goes well! I'd love to buy some more guns but I don't have the money now! I never thought I'd get rid of gun, but I ended up getting rid of my S&W shield to help get the donor F-250 with the diesel.
While I'm sad it's gone, I'd do it again to get the setup in my truck! However, I do need another 9mm as soon as I get the chance!
I'd be happy to give advice if you need it for the AC work when you get around to doing that. I'm no professional HVAC technician, but I did study some refrigeration in my mechanical engineering degree but more importantly I've repaired the AC on 6 different vehicles so I have a good idea of what I'm doing!
If you want another one let me know I will get you one at cost!.
I don't think I have the tools for the AC. I can't vacuum it out I was going to get the new drier and something else I read about. and take it to a shop in town but if you know how to geter done I'm all ears. I have opened the system up to remove the condenser when installing the IC.
Kevin
I don't know, My light does not come on but the parking brake light does when I want it too. Is that the same light?
That would be awesome! I'll have to wait to get some money before I could get another one but once I have the funds I'd like one.
For the AC, it may still be cheaper if you buy the tools than if you take it to a shop, especially if your system is empty now. The most expensive tool will be the manifold gauge set. Unless you can get a good used one, you're probably going to have to spend about 100 bucks on one. A shop is probably going to charge you about 100 bucks to vacuum the system down though (and all they do is hook up the hoses then walk away for an hour or more.) For vacuuming down the system, if you have an Air Compressor, you can go to harbor freight and get their 13 dollar vacuum pump. You hook up the manifold gauge set yellow hose to the end of the vacuum pump, then hook the air compressor hose to the other end of the pump. It works surprisingly well, especially at under 20 bucks. I've used it quite a few times and have had no problems. The only downside is if your compressor is small, you'll have to open and close the valves a bunch to let it build vacuum, but it works fine!
Once the system is vacuum downed and no confirmed that there are no leaks, adding the refrigerant is pretty straight forward as well. It's best to get the cheapest R-134a you can find. You don't need all the leak additives and all the junk that just raises the price. Walmart sells the 12oz cans for under 5 bucks each, while parts stores like to sell them for 12-15 bucks each.
tired to bleed the rear brakes. I could not get the the darn bolt to unscrew to bleed it. its like a 9.5mm or between a 3/8 and 7/16 but neither one fits. either way I cant open them. so they will be replaced with every other ****ing part on this ****ing truck
Man I cannot believe what you have gone through with this truck. Pretty sure those bleeder screws are 7/16. My truck is rust free and they were STILL a bitch to crack open.
I think they are welded in. easier to replace then fix. whats another 500$.. So burned out. thanks for the support though.
