Hello
Old Jun 29, 2016 | 10:00 PM
  #31
MacDaddy's's Avatar
MacDaddy's
Starting a new thread is probably a good idea thank you.
Nice I didn't know you could check that way. Very cool.
Old Jun 30, 2016 | 06:42 PM
  #32
JEFFFAFA's Avatar
JEFFFAFA
On the parking brake cables I would need to know what size rear brakes you have. If it were me I'd replace both. Especially if I locate both part numbers at the same NOS parts company. Let me know which size brakes you have and I'll run those two numbers on some locators.
70/72 F250 (4X2) with 12 1/8" X 2" brakes:
R.H. 72 20/64" long (unknown why Ford didn't list it as 5/16)...D0TZ2A635A.
L.H. 78 39/64" long.............................................. ..............D0TZ2A635B.
70/72 F250 (4X2) with 12" X 2 1/2" brakes:
R.H. 69 21/32" long....................D0TZ2A635C.
L.H. 75 21/32" long....................D0TZ2A635D.
Old Jul 1, 2016 | 05:38 PM
  #33
MacDaddy's's Avatar
MacDaddy's
JEFFFAFA: Thank you for the advice and offering up the help. I don't know how to properly measure drum brakes though haha. Any simple advice?
Old Jul 3, 2016 | 01:45 AM
  #34
JEFFFAFA's Avatar
JEFFFAFA
The best way is to remove your rear hub and drum assemblies and measure the width of your shoes. You will have to do this to replace the parking brake cables anyways. They connect to the rear brakes inside the drums. I strongly suggest you buy a shop manual so you can read up on repairs. But I can tell you the rear hub and drum assemblies and their hub bearings 1969 From serial number F30,001 until 1972 F250,E300,P350 were retained by a 2.56" O.D hex nut. 4 of them. With fold over tab lock washers to keep them in place. Which takes a steel 2 9/16" socket to remove.
Ironmike40
Apr 26, 2020 07:21 AM
Kellyonthemagothy
Jul 9, 2018 09:05 AM
grege
Dec 31, 2017 05:23 PM
SCFlareside
May 31, 2016 11:29 PM
edjunior
Jul 6, 2010 10:08 AM
