'56 On Going Battle
Old Jul 25, 2016 | 01:18 PM
  #31
drptop70ss's Avatar
drptop70ss
Great that you are up and running again!
How did the distributor gear look on the distributor you removed? I was going to ask if you had verified the rotor was pointing at #1 with #1 at TDC, if the distributor had skipped a tooth it would have the same symptoms.
Turning the engine over with the cap removed can also show a worn distributor gear, the rotor will jump around instead of turning smoothly.
I have also used one of the no name HEI distributors, first thing I did when I got it was to put extra heat sink compound on the bottom of the module since heat is what kills them. I have around 3000 miles on it so far, no issues.
Old Jul 27, 2016 | 07:21 PM
  #32
ImSoQuazy's Avatar
ImSoQuazy
Interesting. I will definitely keep an eye on that since it appears that around 3000 something that has to do with the distributor breaks.
The gears looked good. In fact all looked good. Just a Distributor gone bad for no good reason... I guess?
Thank you all for ALL of your help. You make me look at stuff that I would normally not consider. Again, Thank You!!!
benbuilder
23
Feb 17, 2014 01:55 PM
BJ_EPPERSON4201
15
May 26, 2010 08:21 AM
BobcatGuy
Feb 19, 2007 10:41 AM
wndrhmr
May 4, 2004 09:07 PM
mmford24
Apr 27, 2004 08:59 AM
