Bout the best I can do is to move the glare for you.
Your orientation is correct. The black spot on the cover is the back side where there is no sign of anything wrong
Also that looks like the wrong PCM for your truck. The parts are saying 1993 and you have a 1994. A 1993 PCM is wrong for a 1994 truck.
A 1994 truck uses a CCD PCM and a 1993 uses a push-start PCM. They also use different ICM's.
Do you have the calibration number off the drivers door post?
If so maybe we can look up the right PCM for your truck.
The calibration in the photo below is 0-98A-R05 for an example.
O'Reilly will not show the Ford part number. They only show the engineering or drawing number that Ford puts on the part.
Ford will not put a part number on a part.
