1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Reese Towpower interchangeable hitch ball
Old 06-25-2016, 10:45 AM
ufvj217's Avatar
ufvj217
ufvj217 is offline
Reese Towpower Steel Interchangeable Hitch Ball System 74309 at The Home Depot - Mobile
Has anyone used this to tow anything heavy? Wondering how heavy you can trust. I've had one on my scion for about 2 years now bit obviously i only tow a small 4x8 trailer with that but ive never had an issue of it coming loose etc. Nice on my scion bc i frequently change from 1-7/8" to 2". Wondering how it'd work for super heavy stuff on my dually.
Old 06-25-2016, 11:42 AM
Tom's Avatar
Tom
Tom is offline
The published spec is 1,000 lbs tongue weight and 8,000 lbs trailer weight.
Old 06-25-2016, 12:18 PM
TooHuge's Avatar
TooHuge
TooHuge is offline
I just change all my trailer tongues to 2"
Old 06-25-2016, 02:41 PM
Larietpsd's Avatar
Larietpsd
Larietpsd is offline
They make me nervous
Old 06-25-2016, 03:16 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
I went with this setup from Harbor Freight, I picked up a couple of them when they were on sale for $19.99.
Triple Ball Trailer Hitch
The three different ***** mounted on the same solid shank make for a great setup for wrapping a chain or tow strap around when pulling things other than trailers.
Old 06-25-2016, 03:47 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
Yea i have that on my dually and excursion, but sometimes i need a drop hitch and i have one but its just a single ball, so I'm probably gonna pick up the interchangeable set for these scenarios. Plus I'm putting a front hitch on my dually so i can switch it to whatever size ball i need. But yea i love the tri ball one you posted. I use it constantly
Old 06-26-2016, 09:51 AM
baerpath's Avatar
baerpath
baerpath is offline
This what I went with, I'm changing trailer 2-6 times a day and it's easy to adjust with this style.
https://www.etrailer.com/dept-pg-Bal...%7C2_Inch.aspx
Old 06-26-2016, 11:26 AM
EDC8008's Avatar
EDC8008
EDC8008 is offline
I have a 4" drop for my box trailer and then I have a 3 way ball. I constantly shift between the sizes so this works great for me.
Old 06-26-2016, 04:30 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
yea i love the 3 way, works great for my excursion and my dually, only sometimes the dually is a bit high depending on what trailer. usually my buddies trailer, he puts the pin on the 3rd hole when he rests it on the ground, and i can't wind it and raise it high enough to get it on my 3 way on the dually (he has a 2wd excursion lol). on that trailer it has to be on the 4th hole minimum to be high enough for me, so for once in a while scenarios like that, i'd like to have a drop hitch that i can leave locked on my front hitch receiver (front bumper hitch) and take it off when needed to use on the rear.
OrangeRanger
04-13-2015 03:45 PM
KREECH
10-16-2010 06:42 AM
4DAHOSS
15
01-12-2007 11:45 AM
ULTRATEC
09-19-2005 04:44 AM
KJKozak2
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
04-12-2004 11:37 PM
Quick Reply: Reese Towpower interchangeable hitch ball
