After reading a different thread about towing capacities, it got me thinking about a trailer we have at work. It's a home-made 20' dovetail triple axle trailer. It's a bumper pull with a 2 5/16" coupler and chain brackets for a weight distribution hitch. It's titled as 11,500# GTW (can't be correct), but we have TXDOT inspection for 20,000#. It's rarely used, but it occasionally tempts a crew (with a CDL) to use it as an equipment hauler.
My question is, does a weight distribution hitch exist that can handle this trailer fully loaded?
Follow up question. We have various Ford Super Duties, 2006-2008, F250 thru 550, all diesel. We also have 2008-2010 Dodge 3500s, also diesels. Can one of our trucks even tow this fully loaded trailer - with or without a weight distribution hitch?
So, I would say,
1. no u shouldn't haul this loaded with anything u have.
2. u should use a stronger hitch to get to the 16,000 lb max
3. and a wd setup
or
go to gooseneck. really the better approach..
and the trailer is either 10,500 (3*3500lb axles), or 15000, 18,000 or 21000 (5,6,or 7k lb axles).
WD hitch ratings are based on tounge weight not trailer weight.
I've got a 1500lbs Blue Ox unit on my toy hauler.
With tri axle your tounge weight should be lower then single or double axle if the trailer is loaded properly.
I think this trailer has three 7,000# axles. Tongue weight is usually about 10-15%, correct? If it's too heavy for almost all of my trucks and it's too heavy for a weight distribution hitch (even if just slightly), then why does this trailer exist? It's like leaving loaded gun around the work yard.
BTW - Anybody want to buy a trailer? Make you a heck of a deal...
Most of the equipment haulers are design to be hooked up to dump trucks that have the coupler just inches behind the rear axle. The trailer axles are way back and lot of trailer weight goes on the hitch. I am using triple axle, 18k gross trailer and even with my F450 flatbed I had to add airbags to handle the 2000-5000 tongue weight.
For that weigh you need pintle hook. Have never seen WD for those.
To further complicate, when I load my triple 7K axle fifth wheel trailer, the tongue weight actually reduces. It's lighter on the truck loaded than when unloaded. This is due to placing the heaviest part of the load directly over the middle axle on the trailer. Wrap your head around that and you may be tempted to load her up and see what happens.
