Cooling fan circuit 1 or code P0480
Possible causes
- Faulty fan control relay
- Fan control relay harness is open or shorted
- Fan control relay circuit poor electrical connection
- Faulty cooling fan 1
- Fan cooling fan harness is open or shorted
- Fan cooling fan circuit poor electrical connection
What does this mean? What does this mean?
When is the code detected?
The P0480 code is detected when the Powertrain Control Module (PCM) detects that the commanded state of the driver and the actual state of the control circuit do not match.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine overheating
P0480 Description
The electric cooling fan is controlled by the Powertrain Control Module (PCM) through the cooling fan relay based on inputs from the following components:
- The engine coolant temperature (ECT) sensor
- The intake air temperature (IAT) sensor
- The A/C selector switch
- The A/C refrigerant pressure sensor
- The vehicle speed sensor (VSS)
The PCM controls the cooling fan by grounding the cooling fan control circuit which turns ON the cooling fan relay. The cooling fan relay will be commanded ON when the following conditions are met:
- The engine coolant temperature reaches 106°C (223°F) or more.
- The A/C clutch requested.
- The vehicle speed is less than 38 MPH.
The cooling fan relay will be commanded ON regardless of vehicle speed when the following conditions are met:
- The engine coolant temperature is 151°C (304°F) or more.
- The A/C refrigerant pressure is high.
The cooling fan may be commanded ON when the engine is not running under a fan run-on conditions described in the electric cooling fan general description portion of the service manual.
Read more: P0480 Cooling Fan 1 Control Circuit Malfunction OBDII Engine Light Trouble Code | Engine-Codes.com
