Error Codes HELP
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">U2472 </td> <td align="left" valign="top">Unexpected Ignition State </td> <td align="center" valign="top">IC </td></tr></tbody></table>
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">U2023 </td> <td align="left" valign="top">Fault Received From External Node </td> <td align="center" valign="top">IC </td> <td align="left" valign="top">DTC U2023 is set when a module receives invalid network data from another module with a faulted input. RETRIEVE and REPAIR all non-network DTCs in the other modules on the network. </td></tr></tbody></table>
<table border="1" cellpadding="3" cellspacing="0" height="52" width="578"><tbody><tr><td align="center" valign="top">U2511 </td> <td align="left" valign="top">CAN - Data Mis-Match (Receive Data Does Not Match Expected) </td> <td align="center" valign="top">IC
P0480 - Fan 1 Control Circuit
<table border="1" cellpadding="3" cellspacing="0"> <tbody> <tr> <td style="BORDER-RIGHT: medium none" align="left" valign="top">Description: </td> <td style="BORDER-LEFT: medium none" colspan="4" align="left" valign="top">The PCM monitors the fan control variable circuit for an electrical concern. This DTC is set when the PCM detects a open fan control variable circuit. </td></tr> <tr> <td style="BORDER-RIGHT: medium none" align="left" valign="top">Possible Causes: </td> <td style="BORDER-LEFT: medium none" colspan="4" align="left" valign="top">
If I'm reading the descriptions correctly these all indicate connection problems at the fan or between the instrument cluster and /or smart junction box. Any chance something got unplugged and was not plugged back in properly when the fan was worked on?
- Open in the fan control variable circuit
- Cooling fan
