Sponsored by: Real Truck
Maybe I screwed up :(
Old Jun 24, 2016 | 09:59 PM
DetailerDave's Avatar
DetailerDave
I am on my way to Az. I stopped and got gas in Va. I have a rental truck as well. Put gas in both at the same time, same pump. (#7, #8). Rental runs fine. About 1 -1 1/2 miles down the road, my truck lost power, started running terrible. I got off at the next exit and checked fuel pressure found a little bit of water in a test sample. Put seafoam in the tank. Got back on road at 35 mph tops. Off again at next exit. Then after letting truck run while parked for a couple of hours and went to get a motel room. Truck seemed to run better, but now started engine racing on its own. Terrible to drive and surging is atrocious. I am between a rock and a hard place and open to suggestion.
Old Jun 24, 2016 | 10:06 PM
homertwo's Avatar
homertwo
Might want to change the fuel filter.
Old Jun 24, 2016 | 10:23 PM
DetailerDave
My impression at this point is that it is an electronic control issue. Perhaps the fuel conditioners affected a sensor. It did push a lot of white exhaust smoke with a chemical smell.
Old Jun 24, 2016 | 10:38 PM
Bently_Coop's Avatar
Bently_Coop
White could be the Seafoam or coolant burning in a cylinder. Check the coolant level.
Old Jun 24, 2016 | 11:01 PM
DetailerDave
Can some of these fuel additives affect sensors?
Old Jun 24, 2016 | 11:11 PM
Tom's Avatar
Tom
Possible, but not likely. They can't fix bad fuel though.
If the rental is running fine I don't think it's fuel. Is your check engine light on?
Old Jun 24, 2016 | 11:27 PM
DetailerDave
No check engine light, and no codes. I had it scanned with another scan tool, and everything showed as normal.
Old Jun 25, 2016 | 10:09 AM
Bently_Coop
What is your coolant level at compared to before the trip?
Old Jun 26, 2016 | 10:58 PM
41505379's Avatar
41505379
Dave, On our 2001 Impala I have had two different things that caused the engine to run away.
One was the throttle position sensor. If I recall correctly, I could control the speed using the cruise control. This would work on the highway until I came to a steep downhill and had to use the brake.
Second was the idle air control valve. If I remember right, I could not control this with the cruise control. It wanted to run 85 or 90 mph on the level. I pulled it into a dealer with the engine racing. The tech guy turned it off and on and that fixed it for maybe an hour. That was a stressful trip to Dallas and back. Hope my experience will help you, Patrick
Old Jun 27, 2016 | 12:31 AM
twigsV10's Avatar
twigsV10
This is a tough one, I can think of two possibilities for this with no codes.
Less likely but possible, the engine computer has failed?
More likely in my opinion it is two things that failed at the same time, first the catalytic converter pluged killing the power and causing the smoke. Then the idle air control valve started sticking and causing the surging.
There could very well be other better answers to the problems but even just bad gas causing this much of a problem would in my opinion throw an emission code.
Old Jun 27, 2016 | 06:40 AM
Chuck's First Ford's Avatar
Chuck's First Ford
its a rental.... CALL THEM... have them send you a replacement truck ..
They own the truck.. THERE truck broke down on you..
do not try repairs yourself.. LEGAL ISSUES... big time.
Old Jun 27, 2016 | 06:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You didn't read this right. The rental runs fine.
Old Jun 27, 2016 | 07:03 AM
Chuck's First Ford
My apologies..
I did not know or understand he had a caravan trip.
multi vehicle transport setup requiring several trucks. and the Rental truck had NO involvement in the problem he is having.
kemsley21
Apr 11, 2019 11:04 AM
NorthernTracks
Feb 14, 2017 08:51 AM
95-4.9
31
Aug 29, 2016 11:45 AM
sshelton83
6.4L Power Stroke Diesel
Aug 27, 2013 08:58 PM
JohnD333
Sep 6, 2010 01:57 PM
