Trailer connector, no power
Old Jan 11, 2004 | 09:03 AM
Mitchiep's Avatar
Mitchiep
Question Trailer connector, no power
Hi there everyone!!! I have a problem with the trailer connector on my '98 B4000. The connector looks intact and original equipment, but I get no power to it. I have checked and found one dead fuse and replaced it, but still get no power. Is there a switch or breaker I have to thow somewhere??? Thanks in advance.
BTW... I've already found solutions to many of my little ???'s Thanks
Old Jan 12, 2004 | 03:57 PM
Mitchiep's Avatar
Mitchiep
What? not one response????
Old Jan 12, 2004 | 05:19 PM
Chris_ce's Avatar
Chris_ce
90 percent of the problems I have seen with trailer wiring has been the ground. Iwould also check everywhere there is a conector.
Old Jan 12, 2004 | 08:07 PM
Ken00's Avatar
Ken00
You should get right turn at the DG wire (fuse 7, fuse box) left at YE wire (fuse 3, fuse box) and running lights through the BN/WH wire only with the main light switch on (fuse 5 battery junction box). BK wire should have minimal resistance to ground.
Old Jan 12, 2004 | 10:49 PM
Hank85713's Avatar
Hank85713
you need to better explain the problem. no lights period or just one etc. is it plugged into a factory harness, is it a home job?
if it is in a factory plug in is it plugged in under the hood/dash?
be a little more specific when you post a problem if you need a reply!
Old Jan 13, 2004 | 10:01 AM
Mitchiep's Avatar
Mitchiep
Sorry I wasn't clear enough. My problem is that I get no power at all. Tried cleaning out the connector, but this doesn't seem to help. It looks like a factory job. I'll check to see if there is a connector undone under the dash (hadn't considered the possibility) Thanks
Old Jan 14, 2004 | 10:13 PM
Hank85713's Avatar
Hank85713
when you say at the plug, are you referring to the connector plug or the wire loom? If its at the connector there could be a problem with al the connectors, slight but a possibility. Also check the wire loom all the way back as it could have a break in it.
