Sponsored by: Real Truck
01 f250 steering issues
Old Jun 23, 2016 | 06:56 PM
banks0531's Avatar
banks0531
I have a 01 f250, owned it for about 8 months now. Have done a ton of work to it, replacing all worn out parts. It's a v10, replaced so far is ball joints, all tie rods, steering dampener, front sway bar links and bushings and Monroe gas Magnum shocks all around. My biggest problem is the wandering in steering. I put a 2.5" add leaf spring pack to front when I first bought it. It has stock bullet whole wheels and new Firestone's destination a/ts. Also. Tires have been rebalanced and are smooth until I get to 60+mph, its a swirling ride after 60mph.
Could I have bad wheel hubs or do I have an alignment issue? Planning to replace hubs with Napa hubs since I did everything else and I'm sure there bad with 236k miles on truck. Thanks for all advice.
Old Jun 24, 2016 | 06:54 AM
banks0531's Avatar
banks0531
Also, new track bar bushings. Front end is tight, I don't have play in hubs, but I do seem to hear a roar sound from hubs. When it gets to 60mph +, it bounces and wanders. If I do 45-55mph, it's smooth riding and stays pretty straight.
Old Jun 24, 2016 | 02:45 PM
thomabb's Avatar
thomabb
Well, reading what you wrote I am leaning towards the tires. Are they oversize? Wheel bearings worn bad enough to cause steering wander would be evident in the wheel at 40mph or so, long before 60. Can I assume you had a 4 wheel alignment check after replacing all those suspension and steering components?
Old Jun 24, 2016 | 02:46 PM
thomabb's Avatar
thomabb
The 'bouncing' at speed pushes me hard towards the tires...
Old Jun 24, 2016 | 02:59 PM
banks0531's Avatar
banks0531
I hadn't had an alignment yet. I had previous after market 17in wheels and 285 button Terra grappler tires, rode great. The tires I have are 285/70/16. Since I drove fine before and after ball joints, but since last 2 months it's been this way. Should I run alot of air in this tires? There at 50psi now.
Old Jun 24, 2016 | 03:30 PM
thomabb's Avatar
thomabb
You can try airing them up to 60-65 to see if that makes a difference. You could have a belt starting to rupture inside the tire.
Old Jun 24, 2016 | 07:33 PM
banks0531's Avatar
banks0531
I will air them up tomorrow and see how that does. I will talk to tire shop and see if I could get them to check tires out and maybe credit me on them.
Old Jun 25, 2016 | 02:34 PM
banks0531's Avatar
banks0531
I used the pressed in style energy bushings for the track bar. I kinda have my doubts on them, is it possible that those track bar bushings are cause of my issues? When they went bad, shortly after leveling front end, is when all my issues seem to surface.
Old Jun 27, 2016 | 12:29 PM
thomabb's Avatar
thomabb
First impression is 'no', but stranger things have happened.
J-P-A
Aug 25, 2024 06:40 PM
Gear619
Mar 2, 2015 11:07 AM
nkm
General Diesel Discussion
Jun 2, 2011 12:13 PM
Forest
Jan 4, 2007 09:30 AM
deans316
Oct 27, 2005 02:05 PM
