Rim offset - will these fit?
Old Feb 23, 2017 | 12:05 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Do all the suspension stuff before the tires. Especially if you're already getting abnormal wear, why chew up a brand new set? Tires won't be warrantied for wear due to failing suspension components.
If it needs work, it needs work. But it's either spend a lump sum now and get it all done OR spend in smaller chunks that could potentially cause wear and such on recently spent chunks. For example, tired before ball joints and you wear a brand new set of $1500 tires out in 20k miles...
Old Feb 23, 2017 | 12:09 PM
Irish19614x4's Avatar
Irish19614x4
I totally agree with what your saying. Trucks at the shop for the day right now. They are going to check alignment and verify if anything needs replaced then I'm just going to put KO2 on it 285/75/16. Just call it a day and I'll order rear sway bar tonight and do that myself. Otherwise if it's in need of ball joints which it probably does the shop will call me today.
Old Feb 23, 2017 | 12:32 PM
Krazee Matt
Veteran: Navy
Sounds like a plan. There's always the option of piecing together a small lift with Super Duty springs as funds allow. Only reason I did mine in one go was tax return a few years ago.
Old Feb 23, 2017 | 12:55 PM
Irish19614x4
Yea wife and I trying to stick to our original plan pay off debt and what's left we play with. Trying to buy a house in a couple years when I get closer to my Military retirement so can't really spend $2000 or more right this moment. Like you said piece it together and we should be okay.
Old Feb 23, 2017 | 01:00 PM
IMASAP's Avatar
IMASAP
Hey....... 285s will still look good with a 4" lift.
I generally find it's easier to go ahead and do it, then ask for forgiveness, than to ask for her blessing up front.
Old Feb 23, 2017 | 08:32 PM
Irish19614x4
I agree but here you go for now alignment and 285s!
Old Feb 24, 2017 | 05:38 PM
PSUhoss's Avatar
PSUhoss
You just agreed with yourself!!!
That is just plain funny there!
Old Feb 24, 2017 | 06:26 PM
Irish19614x4
Too many posts in one day lol
OKMIC1
May 1, 2008 05:39 PM
Supercouper
Feb 5, 2008 10:39 PM
Cool1996
May 8, 2006 10:25 AM
firefytr29wfd
1997 - 2003 F150
Nov 16, 2005 08:41 PM
LWM97
Feb 8, 2005 09:10 PM
