replacement engine not running
Old Jun 19, 2016 | 02:15 PM
therigwelder's Avatar
therigwelder
Question replacement engine not running
ive put a replacement powerstroke in my 95 f350 and cannot get it to run.I have all new sensors including IPR installed, i am not getting any smoke from the tail pipe also i have no fuel coming out the shrader valve wen i crank the truck.the wts light works fine and the gpr is working.
Old Jun 19, 2016 | 02:29 PM
z31freakify's Avatar
z31freakify
Did you refilled the hpop and rails with oil? It's gonna take a lot of cranking make sure your batts are up to the task.
Old Jun 19, 2016 | 02:37 PM
therigwelder
no i did not, how do i refill the HPOP and rails? i have tried to take the !/4 inch square plug on top of the hpop out and i broke a 1/4 inch drive extesion off and was unable to budge it
Old Jun 19, 2016 | 02:45 PM
z31freakify
That's a tough one, removing one of the sensors and filling thru it, and the rails just remove one of the plugs on the head and get a skinny funnel and fill till it drips out.
Old Jun 19, 2016 | 03:13 PM
therigwelder
maybe i need to clarify,its a used engine so shouldnt the hpop and rails have oil in thhem still?
Old Jun 19, 2016 | 04:51 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
What year is the motor?did you swap all your known good parts to it or use the ones on it?
Old Jun 19, 2016 | 05:00 PM
therigwelder
the replacment motor was the same year as the one i took out.it was a complete motor so i used it. every sensor on the motor is new. i replaced the gpr and firewall starter relay,new fuel pump and new fuel bowl with a new harness.i got it to run briefly in the junked truck i took it out of
Old Jun 19, 2016 | 06:23 PM
coreyallan01's Avatar
coreyallan01
What computer are you using? The one from the donor truck or your truck?
Old Jun 20, 2016 | 12:41 AM
madpogue's Avatar
madpogue
None of the electronics would have any bearing on the fact that there's no fuel feed. Check fuel line connections. Also check to see if primary stage of fuel pump is filling the bowl.
Old Jun 20, 2016 | 07:23 AM
coreyallan01
I failed to note that little tidbit of information...
Old Jun 20, 2016 | 08:07 AM
97-psd's Avatar
97-psd
Did you open the filter to see if there is any fuel in the bowl?
Old Jun 20, 2016 | 09:06 AM
therigwelder
Question
I opened the fuel bowl and filled it up. When I crank it with the lid off the bowl I can see bubbles coming out the fuel and the level appears to rise slightly then falls slightly after I stop cranking.i haven't cranked it long just a few seconds
Old Jun 20, 2016 | 10:05 AM
97-psd's Avatar
97-psd
Good. At least you are getting fuel. Next would be to check the pressure while cranking and the cap back on the bowl
Old Jun 20, 2016 | 11:37 AM
therigwelder
No pressure at all coming out the shrader valve on the fpr
Old Jun 20, 2016 | 06:25 PM
madpogue's Avatar
madpogue
Did you check to see if the first stage of the fuel pump would dispense fuel into the bowl? You would have to empty the bowl in order to do this test.
