Check Coolant
Old Jun 19, 2016 | 12:25 PM
Superduty450's Avatar
Superduty450
Check Coolant
I keep getting the check coolant notice so I ordered up the kit and tested; the RA test indicates the orange caped vial (brown), the contamination test is in the middle more pass than fail. What should I do add vc12 or assume its a bad sensor and take it to the dealer? Do I need to test both cooling systems? mileage 13500
Old Jun 19, 2016 | 01:05 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
I can't help you on what to do but what kit did you order? I ignored mine the first time it came up at around 15000 but it just started coming up again. At almost 30,000 miles.
Old Jun 19, 2016 | 01:12 PM
Superduty450
I ordered the Acustrip kit for Powerstrokes from diesel-filters. com. I would ignore the check coolant message but it comes up everytime I start the truck and stays on until I push ok.
Both systems tested the same
Old Jun 19, 2016 | 01:29 PM
EO2SeaBee's Avatar
EO2SeaBee
You have to go into the menu and reset the message. It isn't a sensor telling you your coolant is bad. It is just a reminder that the computer puts out telling you it's time to test it. If you just acknowledge it by pressing "ok", it will continue to pop up each time you start the truck.
Old Jun 19, 2016 | 10:52 PM
Painted Horse's Avatar
Painted Horse
Ditto the above. Just clear it. there is no sensor. It's just a computer reminder that pops up every so many miles.
Old Jun 19, 2016 | 11:22 PM
JohnD333's Avatar
JohnD333
Yes both cooling systems from the bottom of each radiator per the manual, or just reset and run the risk.
If you are sure no one ever added anything to either tank you are probably fine at both 15 and 30k. Not so at 45k+ - you need to test!
No sensors, just time and mileage turn on the notification.
Old Jun 20, 2016 | 12:28 AM
Tim Young's Avatar
Tim Young
I reset mine at 15k but I think I am going to buy the kit and test it now at 30k.
Old Jun 20, 2016 | 06:46 AM
PlayersZ28's Avatar
PlayersZ28
Mine came up @ 60k mi. I went into the dealer to ask about checking it and the service manager just told me to clear it. In all the tests they had done they never had one fail if it hadn't exceeded the coolant replacement interval.
Old Jun 20, 2016 | 09:33 AM
Rod Bensken's Avatar
Rod Bensken
Dealer told me to just reset message until 45K. Had it checked at 45K and all was good.
Old Jun 20, 2016 | 10:24 AM
senix's Avatar
senix
I tested mine at around 15K and was good. When it comes up again I will just reset it.
Old Jun 20, 2016 | 10:27 AM
Superduty450
Thanks for the menu tip on resetting, that worked.
Old Jun 20, 2016 | 06:51 PM
Dakster's Avatar
Dakster
I agree with the previous posters...
My personal opinion, which isn't based on anything other than observations, this ninny to check it was put in, because the previous generation powerstrokes (6.O and 6.4) had coolant issues. The 6.7 uses a different coolant which isn't susceptible to same issues the previous engines were designed to use. And the 6.7s have a much different Instrument Cluster and computers and such than the last generations did, so it's an easy thing to program. Dealers like it, because it generates A "you need to go in to see them" event.
Rick Cargo
6.7L Power Stroke Diesel
91
Mar 22, 2020 05:22 PM
slownsy
Sep 25, 2016 05:13 PM
nebmike
Oct 18, 2013 08:50 PM
gagnonconsulting
Nov 26, 2012 10:36 PM
teppler
Jan 29, 2010 06:37 PM
