Gasoline odor
Old Jun 18, 2016 | 12:48 AM
Tedster9's Avatar
Tedster9
Spray some old, used hypoid gear oil siphoned out of the differential around. She'll stop complaining about the gasoline odor.
Old Jun 18, 2016 | 10:13 AM
Cobwebman's Avatar
Cobwebman
I would just take the carpet out of the trunk wash in a bit and leave it in the sun to dry. Works every time.
Old Jun 18, 2016 | 10:30 AM
petemcl's Avatar
petemcl
Originally Posted by CharlieLed
Removing Smell from Your Car
Gasoline spills in the car are unfortunately common, especially when you are transporting gas cans. A healthy spritz of Febreeze is a good first choice to cover up the smell, but it won't remove the spill.
To remove as much gasoline as possible, try a mixture of baking soda, white vinegar, and hot water. Mix everything in a bowl and use a rag to gently wipe off the seats or rugs in the car that smell.
Removing Smell from Your Carpet
Finally, if the smell of gasoline is lingering in your carpet, you will want to be careful about what you use to clean it up. The best thing to do is to gather two mixing bowls, a few clean rags, hot water, baking soda, a wet/dry vacuum, and vinegar.
Use one rag to soak up any residual liquid in the area where the spill occurred. Then, in one bowl, mix a little hot water with vinegar, and in the other bowl, mix hot water with baking soda into a paste-like consistency.
Apply the vinegar and water solution to the area of the carpet that has the odor on it. Use the vacuum or a rag to soak and clean up the affected area. Then cover the area with the baking soda and water mixture. Use the vacuum or a rag again to wipe off and clean the spot. Then use hot water to clean the area and allow it to dry freely.
Good info CharlieLed. I was wondering about vinegar as a solution.
Old Jun 18, 2016 | 06:04 PM
56panelford's Avatar
56panelford
I think we have it under control now, vinegar and baking soda and a good airing out today seemed to help a lot today..
Old Jun 18, 2016 | 07:40 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Im so glad you got the smell out of there. After all the work you put into making that the truck into the showpiece that it is, and any damage to it is heart breaking. I just re read your original post (#1) and see that you had taken the carpeting out, hopefully you be able to reuse it after treatment.
Old Jun 18, 2016 | 08:29 PM
56panelford
It's all back together and seems to be alright Jimmy. This was in my car not the panel..
TexasRho83
Nov 8, 2008 12:18 PM
omni
General Automotive Discussion
Aug 10, 2007 07:39 AM
jclj2003
Jul 14, 2005 12:13 AM
nick_wood
Kansas Chapter
Jul 6, 2005 09:28 PM
Munkey
Appearance & Dress-Up
Apr 16, 2002 12:39 PM
