Gasoline odor
Old Jun 17, 2016 | 06:25 PM
56panelford's Avatar
56panelford
Gasoline odor
I needed to pick up some gas for the lawn mower and while carrying it home in the truck of the car some leaked out onto the carpet and the smell has gone through the car and having trouble getting rid of the smell. We have scrubbed the truck out , removed the carpet but still very strong.. Any ideas of how to get rid of the smell ?
Old Jun 17, 2016 | 07:01 PM
avf100's Avatar
avf100
A match. ��
Old Jun 17, 2016 | 07:02 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Just a guess but a mix of cat litter and baking soda mite absorb it, sure couldn't hurt ??????? That's a real drag John.
Old Jun 17, 2016 | 07:03 PM
56panelford
Thanks for your help..
Old Jun 17, 2016 | 07:07 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Leave all the window down for a few days, especially while driving around. Usually works for me when gas spills. But once I spilled gas on a fatigue hat while filling the mower and had to run it through the washing machine several times.
Old Jun 17, 2016 | 07:11 PM
56panelford
I'm hoping through time it will disappear, it bothers the wife more than it does me but she is very sensitive to odors where I've worked around them most of my life..
Old Jun 17, 2016 | 07:17 PM
toby tough's Avatar
toby tough
May be some Fabreeze. They make some for air now I guess.
Old Jun 17, 2016 | 07:20 PM
56panelford
The wife can't tolerate Fabreeze because of allergies
Old Jun 17, 2016 | 07:30 PM
toby tough's Avatar
toby tough
My BIL's wife is sensitive too. Preservatives and perfume give her headaches. The baking soda would probably work pretty good. Spread some around on the floor in the back there. Works good in our fridge.
Old Jun 17, 2016 | 07:36 PM
56panelford
That's what we've been doing so far but still hasn't gotten rid of it yet, maybe just not patient enough, it's only been 3 days..
Old Jun 17, 2016 | 08:39 PM
avf100's Avatar
avf100
Originally Posted by avf100
A match. ��
I posted another reply after this one, apologizing for this post. And that I just couldn't resist.
But for some reason, probably user error, it didn't post.
So anyway I think you just need to let it air out. When I spill gas in the garage the smell goes away after a day.
Old Jun 17, 2016 | 08:43 PM
56panelford
I didn't take offense ,I knew it was humor and why I thanked you...
Old Jun 17, 2016 | 09:35 PM
topmoo's Avatar
topmoo
I have had good luck with Ozium or X-0. Find them on Amazon.
Old Jun 17, 2016 | 09:39 PM
56panelford
I'll check that out Topper if there is no change in the odor in the next couple days..
Old Jun 17, 2016 | 11:21 PM
CharlieLed's Avatar
CharlieLed
Removing Smell from Your Car
Gasoline spills in the car are unfortunately common, especially when you are transporting gas cans. A healthy spritz of Febreeze is a good first choice to cover up the smell, but it won't remove the spill.
To remove as much gasoline as possible, try a mixture of baking soda, white vinegar, and hot water. Mix everything in a bowl and use a rag to gently wipe off the seats or rugs in the car that smell.
Removing Smell from Your Carpet
Finally, if the smell of gasoline is lingering in your carpet, you will want to be careful about what you use to clean it up. The best thing to do is to gather two mixing bowls, a few clean rags, hot water, baking soda, a wet/dry vacuum, and vinegar.
Use one rag to soak up any residual liquid in the area where the spill occurred. Then, in one bowl, mix a little hot water with vinegar, and in the other bowl, mix hot water with baking soda into a paste-like consistency.
Apply the vinegar and water solution to the area of the carpet that has the odor on it. Use the vacuum or a rag to soak and clean up the affected area. Then cover the area with the baking soda and water mixture. Use the vacuum or a rag again to wipe off and clean the spot. Then use hot water to clean the area and allow it to dry freely.
