Rust Prevention Maintentance
Old Jun 17, 2016 | 03:48 PM
ktgovols's Avatar
ktgovols
I'm sure many of y'all know this, but in case you don't, or if you haven't thought about it in a while.
While continuing to strip paint on my cab, I realized the rear corners were completely full to the floorboard on both sides as I washed the stripper with a hose and nozzle.
I stuck my hand down in the rear corners and I'll tell you, it was a literal cornucopia of trash. There where candy bar wrappers, gas station carbon paper receipts, nails, washers, pencils, cigarette foil, not to mention about 3/4" of muck and mud. I got to thinking that I probably needed a tetanus shot while I was feeling around in there.
I spent almost half an hour cleaning out each side of the distgusting mess.
I don't recall when I was driving my truck ever cleaning these out. I did clean out the door drain holes, but never the cab corners. They aren't much bigger than a 1/4" so it doesn't take much to plug them.
There are also two drain holes in floor pan rib where the gas tank sits that need to be cleaned as well.
The corner holes are here. Sorry. I didn't get a picture from the underside.
This is the hole in the floor pan rib. There is one on each side.
I know that many of you may be like me and never have thought about these. Also, I know many folks have cleaned and reapplied undercoat to the bottom floor pan and may not have thought to make sure they were clear after you got finished.
Or maybe I'm the only dummy in the group! LOL!
Keith
Old Jun 17, 2016 | 05:50 PM
Justboy's Avatar
Justboy
You're right to point this out. If water lies it doesn't take long at all to do damage. I found some old tools down there but not much else. The tools faired worse than the cab corners mind you! Not sure what the answer is other than a regular check though. Something to bear in mind when you trim it that you might slow evaporation and restrict access.
Old Jun 17, 2016 | 06:13 PM
raytasch's Avatar
raytasch
Believe Nothing
Thanks for the reminder. Worse yet when ms mouse decides to make her nest in one of the cab corners.
Old Jun 17, 2016 | 09:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I think those holes under the gas tank are for rubber pads?
Old Jun 17, 2016 | 10:38 PM
ktgovols's Avatar
ktgovols
Maybe so Ross. I'm not sure.
My rubber pads were about an inch over from the holes. But maybe a P.O. did that.
Keith
Old Jun 18, 2016 | 10:24 AM
petemcl's Avatar
petemcl
My cab corners were the same. Lots of junk and trash in there. It doesn't take much to fill up those drain holes. I have thought about filling up those rat holes with foam. Has anyone done that?
Ford SD
Paint & Bodywork
Apr 24, 2015 01:26 PM
ford1954250
Jul 1, 2013 09:22 PM
rustywheel68
Jun 10, 2012 05:29 PM
Lakotas53
Dec 1, 2010 06:34 AM
BlueOvalRage
Jan 6, 2003 07:00 AM
