Question about axles
Old Jun 17, 2016 | 09:33 AM
Nerdy's Avatar
Nerdy
Question Question about axles
So I have a '79 f100, currently with a 351W in it, but I'm planning to eventually do a Cummins swap. Is the Dana Super 60 a good idea for this? What would be the best?
Old Jun 17, 2016 | 09:34 AM
Nerdy's Avatar
Nerdy
Also, first post
Old Jun 17, 2016 | 09:48 AM
wyrm73's Avatar
wyrm73
2WD or 4x4? A 351W is not stock, but an easy replacement from the 302 in some 2WDs. Are you sure it is not a 351M?
Those that have more experience with the Cummins can steer you better, but the first thing I noticed was a F100. You will have a lot more to worry about in the beefing up the suspension department than you will with which axle is better. Those are heavy engines.
Old Jun 17, 2016 | 09:52 AM
Nerdy's Avatar
Nerdy
It's a 4x4. I apologize, I was reading up about the 351, it is a 351M.
What do you recommend, then?
Old Jun 17, 2016 | 10:03 AM
wyrm73's Avatar
wyrm73
Like I said, the Cummins crowd will eventually join in here and please listen to them rather than me, but from the little I have read you will be looking at custom made springs. But I have yet to see anything on a F100/150 which had front coils rather than leafs. I fear that one fact could be a HUGE challenge as from what I recall on my F100, the coil bucket is not all that stout. It was designed for a much lower weight. My first thought would be a conversion to leaf springs on the front or some fabrication work to beef up the stock coil mounts.
That said, the best answer I can offer for your axle question is D60 front seems to be the weapon of choice and the rear could be a matching D60 or stick with the 9".
A quick reading list that may help:
https://www.ford-trucks.com/forums/1...il-burner.html
https://www.ford-trucks.com/forums/1...ld-thread.html
Old Jun 17, 2016 | 10:18 AM
Nerdy's Avatar
Nerdy
Thank you so much for the help.
I'll be sure to check it out. Thank you again.
Bigford4x4_83
Mar 24, 2004 03:47 AM
knucklehead11
Jul 10, 2003 10:33 PM
cleveland short
Sep 14, 2002 05:34 AM
trueblue_79
Feb 17, 2002 12:57 PM
