Sponsored by: Real Truck
2007 f250sd 5.4 problems
Old Jun 16, 2016 | 07:14 PM
Puggles1228's Avatar
Puggles1228
I have a 2007 ford f250 sd xl rwd auto 5.4 l 3valve triton with 126000 miles. Problem is rough running, ac stops when under a load, lack of power, you name it. 25% of time it will run fine, rest of time it can barely make it on its own power. No rattle of the timing chain as I have heard from others on this noise, starts and runs fine at idle. Once moving it shares all the above quirks. From what ive read I could chase these problems for years, or replace motor with a rebuilt one from either ford or other manufacture. I am guessing it is the problems with the VVT selonids. I have replaced them once already and have less than 10000 miles on them. Ive replaced coil pack 5 at one time due to it poping the code. I also have codes po352 showing today.
goodoleboi96
2004 - 2008 F150
Dec 10, 2015 11:10 PM
ugh3012
May 15, 2015 09:14 PM
Arod156
Modular V8 (4.6L, 5.4L)
Jan 28, 2015 07:58 PM
NorthernOutpost
2004 - 2008 F150
Mar 18, 2009 10:16 PM
